Old May 14, 2012, 05:36 PM
Stosh's Avatar
Originally Posted by dandelioneater View Post
If you want a really good z77 or z68 board definitely consider picking up an asus sabertooth. I just got mine (z77) and it is one heck of a board. I can honestly say it is the best board I have ever owned. Not a single issue with it so far.
That's the board i've pretty much decided on for my full sized build.
I was having a tough time deciding between a full sized build and a mini itx build, but I decided to do both.
Old May 15, 2012, 06:50 AM
crazyea's Avatar
Is there a reason you didnt consider the Asus Maximus V Gene? Great board.
Old May 15, 2012, 07:30 AM
Stosh's Avatar
just size. a micro atx is almost 3" larger both ways vs. a mini-itx board.
i'm going to do a custom enclosure out of some exotic hardwoods, and i've got some good ideas for a very small form factor.
I probably should be stating this in all my threads on these projects, but i'm not a gamer.
so the performance needs are much less than it would be for some of you.
Old May 15, 2012, 01:13 PM
elmorejohn46's Avatar
I would go with the ASRock Z77 Exetreme6 or even better the ASRock Z77 Professional.I went with ASRock with my i7-3820 and love it ,overclocks like mad and is very stable.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
Old May 15, 2012, 06:52 PM
Stosh's Avatar
The Asus/ASRock stuff seem to show up at the top of everyone's list.
Advice on Motherboard Processor and Ram shadowwolf128 LinusTechTips Q&A 10 February 14, 2012 10:09 AM
New/Upgrade Gaming Build Advice (Updated with Parts List) Midimatt New Builds 7 January 27, 2012 02:47 AM
Gigabyte Motherboard RMA Advice Arinoth Troubleshooting 3 January 17, 2011 07:31 PM
Need Advice - New Motherboard And/or Ram? Slaughter CPU's and Motherboards 3 January 13, 2011 04:14 PM
Advice on motherboard shanji CPU's and Motherboards 5 February 16, 2010 06:06 PM
