  #21 (permalink)
Old May 11, 2012, 02:16 PM
Adzsask's Avatar
Originally Posted by Linus View Post
I've seen sealed CPUs from AMD and Intel with marks all over the spreaders. It's perfectly normal...
But is it acceptable? I know if I ever get anything marked up it is instantly returned, even a $2 part, let alone something worth hundreds of dollars.
  #22 (permalink)
Old May 11, 2012, 02:22 PM
3.0charlie's Avatar
Looks fine to me, those marks on the side are from tool marks left from the die punch. And marks on the HSF contact surface are from the test bench the manufacturer uses on new chips. I've seen those so many times on Intel chips too.
Your problem is somewhere else. If need be, you can contact DC_Support, he works for DC and is a member here.
Hydro-Quebec is salivating...
  #23 (permalink)
Old May 11, 2012, 02:33 PM
sswilson's Avatar
It depends on whether or not the box was sealed. If it was sealed then it's manu testing, if the box wasn't sealed, it's a return that's being pawned off as new by the distributer.
  #24 (permalink)
Old May 11, 2012, 03:55 PM
Originally Posted by stoanee View Post
How come only 14 days? Also, AMD warranty is a lot longer than that.
This is directcanada's warranty. AMD's warranty is 3years after the 14days past...
  #25 (permalink)
Old May 11, 2012, 03:59 PM
But everytime when I try to boot up, I either get a bluescreen or it just freeze. Sometimes I might be lucky and get past boot up, but in a few seconds the computer freeze. What I mean by freezing is the whole computer not responding. I have to force shut down pressing the power button for five seconds.
  #26 (permalink)
Old May 11, 2012, 04:05 PM
Which is why I asked what motherboard you're using. If you're using a motherboard with inadequate power delivery to run a Phenom II with 4 or more cores that could be the culprit.
  #27 (permalink)
Old May 11, 2012, 04:19 PM
3.0charlie's Avatar
...or 32gb of ram with improper NB voltage. Full specs please.
  #28 (permalink)
Old May 11, 2012, 04:58 PM
M2N-78(violet) Motherboard (AM2) *supports Athlon II and Phenom II*
6GB RAM DDR (SAMSUNG)
450watt rosewill PSU
HD4650 GPU
500GB WD HDD
DVD Burner
Hp pavilion case
EDIT: I forgot to tell you, when I first got the PC, it had an athlon II x4 620 .
  #29 (permalink)
Old May 11, 2012, 05:10 PM
Soultribunal's Avatar
HD4650 GPU
500GB WD HDD
DVD Burner
Hp pavilion case
I may have missed it what CPU are you trying to install into that board? You might be past the power envelope of the board.
Or it might not support it, or have the correct BIOS.
Thats an old board.
-ST
www.realhardwarereviews.com
  #30 (permalink)
Old May 11, 2012, 05:17 PM
BigPhatPaulie's Avatar
Plus for a phenom (x6?) that psu is a bit light.... like the last guy said it could very well be the board/ psu are inadequate
ebgames sells refurbished laptops and PCs? BrianHanna Off Topic 16 January 21, 2010 05:51 PM
Anyone know a canadian site that sells this? BrianHanna Cases 2 January 7, 2009 12:25 PM
AMD sells 8.1% to Abu Dhabi Gov't Babrbarossa Press Releases & Tech News 4 November 18, 2007 06:10 PM
$200 Linux PC @ Wal-Mart Sells Out! qwerty O/S's, Drivers & General Software 1 November 16, 2007 09:45 PM
AMD VP sells shares Babrbarossa Press Releases & Tech News 5 June 4, 2007 05:18 PM
