Old May 8, 2012, 03:27 AM
Unhappy ASUS mobo flashed bios issues.
Hey guys.
So my friend has an ASUS m5a78l-m lx, and his evening I tried to update the bios for him via the Ezflash method. So I got the latest bios update and put it on a USB, restarted the pc, went into the bios, selected Ezflash and went into myusb drive and selected he update and it said that it was updating. Finally after waiting a bit it finished and said that the update was complete, then it restarted and there was no bios beep, no boot screen no nothing, all fans were running and so on but there was no boot at all.
My question is simple... What went wrong?
Old May 8, 2012, 03:57 AM
sswilson's Avatar
Did you try a cmos reset? How about booting with the original driver disk in the ODD (many have a default bios they will try to load, but you need to check the manual).
Old May 8, 2012, 05:25 AM
b1lk1's Avatar
Why did you update the bios? Updating bios should only be done when there are problems.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
[FS] Sapphire HD 5870 flashed to unlocked bios Arinoth Buy/Sell & Trade 9 October 7, 2010 06:17 AM
Can the BIOS on a 5870, pulled from a Dell, be flashed? Lima Video Cards 14 September 13, 2010 09:33 PM
[FS] Asus X38 P5E lga775, flashed to Rampage formula Flintblade Buy/Sell & Trade 1 August 7, 2010 10:36 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
Flashed My BIOS, someone please take a look! bushwickbill Overclocking, Tweaking and Benchmarking 5 October 9, 2007 04:55 PM
