Old April 3, 2008, 11:22 AM
zlojack's Avatar
Default Thinking about a secondary rig
I have the following parts kicking around:
Antec 900
Coolermaster Extreme Power 650w
4GB RAM (PC2 5300 I think)
E4500
DVDROM
So basically with a cheap HD and Mobo, I could set up a secondary folding rig and a backup rig.
I'm looking to spend as little as possible on this, but the mobo should be able to OC some. I'm still not sure if I'll even buy a monitor for it (unless I can find a nice cheap old CRT or something), just set it up and let it run and just check it periodically.
I'd probaly just install Linux as the OS.
The only thing I'd like is for the mobo to be able to somewhat oc the CPU, so I'd be willing to spend a bit more there.
Also, this stuff doesn't have to be new, so if anyone has anything they're looking to dump...let me know.
Old April 3, 2008, 11:25 AM
where do u live
if ur around toronto
i got a 17 inch CRT monitor for like what 10 bucks lol
Old April 3, 2008, 03:38 PM
biff's Avatar
A DS3L would fit the bill for a mobo. If you're using it for backing up a bigger HD might be a good idea, of course it is a great place to throw all those smallish HDDs that most of us have lying around.
This might interest you, I've toyed around with a program called RealVNC - RealVNC remote control software. It's a remote desktop program that is pretty easy to setup and does what it's supposed to do and better yet it's free.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old April 3, 2008, 04:37 PM
zlojack's Avatar
Thanks for the tip!
Old April 9, 2008, 07:03 PM
zlojack's Avatar
Ok...I found a P5K for $85 new back from RMA. Not a bad board for that price!
I should be able to get some stuff from work and hopefully put together a decent secondary rig...
