  #21 (permalink)
Old April 13, 2008, 10:41 AM
Supergrover's Avatar
Originally Posted by gimark View Post
It should still boot to bios though shouldn't it? That way I can change the settings so I can boot from the windows disk and format the old.
Yup it would only affect you after POST when you attempt to BOOT the OS.
R.I.P.
  #22 (permalink)
Old April 13, 2008, 11:54 AM
gimark's Avatar
Thought so. It doesn't boot to bios, just turns the fans on, shows power to mobo, then off, then on again and so on. Must be defective.
  #23 (permalink)
Old April 13, 2008, 01:03 PM
r0k0's Avatar
oops.. :P too slow haha
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
  #24 (permalink)
Old April 16, 2008, 05:17 PM
gimark's Avatar
One last question before I send it out for RMA. Would the cpu not being supported by the current bios version of the mobo cause this to happen?
  #25 (permalink)
Old April 16, 2008, 05:33 PM
r0k0's Avatar
i know for a fact that the stricker needs a Beta version so that the new .45nm cpu's will work.. but its beta.. i wouldnt touch it.. check online for your board and look at the last bios that was released..!
maybe you just need a new bios for the Extreme Version..! never know
Main Rig
Canadian Eh ?
  #26 (permalink)
Old April 16, 2008, 06:07 PM
You do have both power connectors (the 24-pin and the 4-pin) plugged into the mobo? Try re-seating the RAM and the CPU.
  #27 (permalink)
Old April 16, 2008, 06:31 PM
gimark's Avatar
Tried that, about 15 times lol
Sent it out for RMA, hopefully that will fix the problem. Thanks for everyones help. Its frustrating but I can still run the old system for now.
Mark
  #28 (permalink)
Old April 16, 2008, 06:44 PM
3.0charlie's Avatar
I think you gave up too fast. The DS3R should recongnize the new chips no problem and have the proper BIOS already flashed - the EP35s are the newest Gigabyte boards.
You are running Crucial Tracers and XMS2 sticks? I would have tried to boot with a single XMS2 stick, since I know those do boot with 1.8V - unlike the Tracers, which need 1.9V-2.0V.
  #29 (permalink)
Old April 16, 2008, 06:54 PM
gimark's Avatar
I tried each stick of ram individually, tested psu, and tried much more
  #30 (permalink)
Old April 16, 2008, 07:00 PM
3.0charlie's Avatar
Good, you did go to such extent in testing. Did you try a CMOS reset with battery removal?
