Old April 3, 2008, 05:37 PM
. Get the Noctua NF-p12 http://www.ncix.com/products/index.p...facture=Noctua for the best and quietest of fans. I have that set up and I cant even hear it running.
As for the MX-2 not only is it better but it is a heck of a lot cheaper too http://www.ncix.com/products/index.p...ctic%20Cooling
Now, dont forget to price compare your system with Direct Canada too. ie. Thermalright ULTRA-120 Extreme 6 Heatpipe Cooler LGA775 Heatsink *Fan Not Included* - DirectCanada vs http://www.ncix.com/products/index.p...e=thermalright
Have you considered a E8400 for a processor?
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old April 3, 2008, 06:00 PM
gimark's Avatar
lol, I live in a small rural town in Manitoba. I doubt there are any other computer addicts like me within a hundred miles. I did build a computer for a friend around here who put in a Q6600, could use that. The board does say "The Intel® P35 Express Chipsets support the latest multi-core processors up to FSB 1333MHz, including the upcoming 45nm platform" . Got the Noctua on my cart, thanks for that information! Had actually already been price matching, but thanks for making sure I know. Makes quite a difference on the end cart almost a hundred in savings by price matching.
I did consider an e8400 but felt like stepping it up a notch with the quad core. I did notice that the e8400 was rated better for single usage (which will probably be what I'll be doing).
It looks quite a bit different then when I first started researching last week, here is the order:
Intel Core 2 Quad Q9450 Quad Core Processor LGA775 2.66GHZ Yorkfield 1333FSB 12MB OEM No HSF
Gigabyte EP35-DS3R ATX LGA775 P35 1600OC FSB DDR2 1200OC 1PCI-E16 SATA RAID Sound GLAN Motherboard
Arctic Cooling MX-2 Thermal Compound Paste NON-ELECTRICAL Conductive 4 Gram
Noctua NF-P12-1300 120MM Ultra Quiet Cooling Fan 1100-1300RPM 63-92M3/H 12.6-19.8DBA Molex
Thanks again for all the quick and informative replies!
Mark
Old April 3, 2008, 06:06 PM
Prof. Dr. Silver's Avatar
SHAAWEEEEEEEET!!! Don't forget....We want pics!!!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old April 3, 2008, 06:53 PM
biff's Avatar
That is certainly true but chances are the board (if it's been sitting on a shelf for any length of time) may not have an up to date BIOS which may be needed to make the above statement true. It doesn't hurt to ask though I'm sure borrowing your friends Q6600 for a few minutes to flash it yourself would git 'er done too.
Looks like a complete order to me!
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old April 4, 2008, 03:26 AM
sswilson's Avatar
Yeah, they're able to support them, but when the P35 chipset boards were released, the full final spec for the new procs wasn't available so while they've got the ability to run the spec, all P35 boards need a bios update of some form to recognise the chips.
This is an issue with virtually all boards currently available through retail channels.
Looks like a pretty decent build you've got going there!!!!!
Edit..... What he said...... :)
Old April 4, 2008, 01:11 PM
SugarJ's Avatar
I was able to boot my GA-P35-DS3L Rev 2.0 with the E8400, but the first thing I did after XP loaded was to update the bios.
Old April 11, 2008, 07:42 PM
gimark's Avatar
Good news is everything arrived, took tons of pics and they will be up shortly.
Bad news is its not working yet. When I hit the power it starts up and then shuts down in approximately 3 seconds. Can sure here that cpu fan go swooosh. Will keep working on it.
Mark
Old April 12, 2008, 10:44 AM
gimark's Avatar
Been working on this for about 10 hours, starting to get frustrated heh. I'm not an inexperienced system builder but I've ran out of ideas (other than the mobo and/or cpu is defective) any advice I'd appreciate a lot.
I've put it back the way it was originally and that works fine, but as soon as I put on the new cpu, and mobo, it won't boot up. It starts running and then shuts down in a few seconds then it starts itself back up again and stops; it will stop doing this if I hold the power button a few seconds it shuts off and stays off.
It shouldn't be the ram, because they work on other systems without glitch, same with the psu. I'd rather not have to go through the rma process so any ideas would be greatly appreciated. Thanks!
Mark
  #19 (permalink)
Old April 13, 2008, 06:30 AM
r0k0's Avatar
once you put in a new mobo.. you have to reformate.. their no option for that since it doesnt use the same chipset and you need a reformating :(
i only got lucky once.. i swapped mobo and i did'nt need to reformate..!
Intel i7 3930K / 16GB Corsair Vengence DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 770
Corsair 480GB SSD / 1TB WD Black
IN WIN 303 / EVGA NEX750 Gold
  #20 (permalink)
Old April 13, 2008, 10:22 AM
gimark's Avatar
It should still boot to bios though shouldn't it? That way I can change the settings so I can boot from the windows disk and format the old.
