Old March 31, 2008, 10:11 PM
Default NEW BUILD ADVIce
so the E8400 are coming im ready for my new build
my budget's around 1000 1100 maximum with test
here's whats on my mind
CPU: C2D E8400
HSF: ACP7
MB: P35-DS3L or DFI LP P35_T2RS -which one would get a better OC
RAM: MUSHKIN XP2 6400 3-3-4-10 timing
PSU: CORSAIR 620W hx series
CASE: CM690
FANS: FEW 120m scythe kaze
FAN CONTROLLER: Sunbeam RHeobus
HD: SEAGATE BARRACUDA 500GIG
1 DVD lightscribe SATA
VIDEO CARD: 8800GT Evga
is there any better overclocking board?
are the ram the best for ddr 800 or should i spend on ddr 1066
i know the ram can hit 1000 mhz?
Old March 31, 2008, 10:15 PM
Prof. Dr. Silver's Avatar
So far....nice build...
I personally like the DS3L a lot, but I don't know the other board....As for the RAM...go for the 1066MHz....will work better with OC'ing your stuff! Heatsink I would choose either a Noctua or the TRUE! Good Luck choosing and leave some pics!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old March 31, 2008, 10:47 PM
what if i overclock my ram
Old March 31, 2008, 11:03 PM
Unfortunately...like many guys here will say: Buying computer hardware is like playing the lottery! Sometimes you win sometimes you loose! That means that you'll never know how good of an OC you'll get out of your 800MHz memory for example....it might be 1100MHz but it also could be 810MHz.....See what I mean? It is a guessing game.
That's why...play it safe and buy better gear....! Then you won't end up with a sad face if your can't OC your CPU because your RAM is holding you back at 855MHz!
Old March 31, 2008, 11:18 PM
For the HSF, you might wanna grab an Ultima-90 from NCIX as it's on sale right now. Pair it with a good fan and you're good to go. Another good choice is the Ninja Copper, but it's a tad more expensive but it already comes with a fan (but slow) and it looks cooler.
The RAM is good, as the support from Mushkin is excellent. But if you want guaranteed speeds get some Patriot Extreme Viper from NCIX, I believe same price as the XP2 but it's 1066 instead of 800.
Antec NSK 6500 w/ TriCool intake, S-Flex F exhaust
Corsair HX520
Gigabyte GA-965P-DS3 Rev1.0 @ 500FSB
Intel C2D E6300 @ 3.5ghz 1.45V
Arctic Cooling Freezer 7 Pro
Mushkin (996576) 2X1GB HP2-6400 @ 1000mhz 5-5-5-15 1.9V
eVGA 7600GT KO @ 630/880
Seagate 7200.10 320GB
Samsung SH-162
Samsung 205BW
Logitech Media Keyboard
Logitech MX518
Old April 1, 2008, 12:32 AM
ULTIMA 90 for TRUE?
isn't true better
but fitting it is ahuge problem right?
Old April 1, 2008, 08:13 AM
SugarJ's Avatar
The TRUE is the best out there, but it is MASSIVE.
The CM690 is a mid-size case, size may be a factor fitting this HSF in.
Old April 1, 2008, 09:59 AM
Synth's Avatar
Default DFI ...
I personaly think you can't go wrong with the DFI... sure the gigabyte is cheaper, but it lacks a few features I find essential in its bios. And for shear overclockability, the DFI gets my vote again.
My .02
