Old April 14, 2012, 12:25 PM
Default What is up with my i7 920??
Okay so i bought my build 3-4 years ago, and my 920 has served me well since now. Its been dummy overclocked to 3.2GHz since the day i bought it. I have a Noctua NH-U12P air cooler in a pull method (since my motherboard doesnt give me enough room for a push/pull config). All of a sudden, im getting retarded temperatures at IDLE... I have applied and re-applied thermal paste but no difference. I cleaned the heatsink for dust and i HAVE to keep the window open for cold air to flow into the case or i get a restart everytime.
2 pics, one at IDLE, one playing BF3
Old April 14, 2012, 12:36 PM
Soullessone21's Avatar
Have u tried reseating Ur CPU, removing it and putting it back in, as well as checking for bios updates? Those are great places to start u might of said that already haha but I'm on the iPhone app and it cuts off half the page.
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
Old April 14, 2012, 12:38 PM
No i havent and thanks for your advice. Update my motherboard BIOS?
Old April 14, 2012, 12:40 PM
What is the model of Ur motherboard and brand I will link u to what u might need?:)
Site and Forum:
Old April 14, 2012, 12:43 PM
EVGA X58 3x SLI Motherboard, and thanks :)
Old April 14, 2012, 12:48 PM
heres a link to your system bios as well as instructions on how to install the update, I myself have never owned or supported EVGA (work for a ASUS repair Center) but I am sure it will be fairly straight fwd
EVGA Download Center
Site and Forum:
Old April 14, 2012, 12:52 PM
Thanks :D will try and let u know how it turns out
Old April 14, 2012, 12:53 PM
sounds great if you need any more assistance just PM me, always here to help
Site and Forum:
Old April 14, 2012, 01:18 PM
Adzsask's Avatar
Wow thats odd, sounds to me like your TIM dried out, or maybe even heatpipes are losing there efficiency, I am running an EVGA X8 SLI Micro, my temps are much lower, but also cooling with a 360mm RAD, also I had a really old bios on this board when I bought it, and my temps never changed when the bios was updated. I would toss a new cooler on if you have a spare and see if your cooler is dying(heatpipes do wear out). Pulling the CPU couldn't hurt to try also.
Old April 14, 2012, 01:21 PM
sswilson's Avatar
I'm wondering if maybe the heatpipes didn't lose their integrity and all of the gas has leaked out......
