Old April 11, 2012, 03:38 PM
Default Asus X79 Rampage IV Formula vs IV Extreme
Hey guys,
Just wondering if it's worth the extra cash to go with the Extreme Version vs the Formula Version
Obviously both are overkill motherboards to begin with, and the Extreme version has more Ram slots, but would I be disappointed with the Formula?
I'm pairing it with a i7-3930K
Thanks,
Chomie.
Old April 11, 2012, 03:52 PM
JD JD is offline
If you don't plan to use 8 DIMMs, then I think you'd be more than happy with the Formula.
Old April 11, 2012, 06:39 PM
SugarJ's Avatar
If you are a benchmarker, get the Extreme. If you are a gamer/overclocker, the Formula should be fine. If you plan to put the max 4x8GB DIMMs in the Formula, you'll probably have to shop at Newegg, NCIX doesn't appear to carry much stock.
Old April 11, 2012, 07:19 PM
I live in Calgary, Memory Express is my home ;) Thanks for the input!
Rampage III Formula & Extreme 975, what RAM? dberladyn RAM 1 November 30, 2011 04:03 PM
ASUS Launches the Rampage III Extreme and Maximus III Extreme Motherboards FiXT Press Releases & Tech News 4 April 16, 2010 05:40 AM
ASUS Rampage Extreme or ASUS Maximus II Formula AmuseMe CPU's and Motherboards 3 July 20, 2009 09:46 AM
Does the optional fan of Rampage Formula works with Thermalright Ultra-120 eXtreme? Startup123 CPU's and Motherboards 2 June 24, 2008 12:56 PM
Rampage Formula + ultra 120 extreme... CraigHf CPU's and Motherboards 2 May 10, 2008 01:55 PM
