Old April 11, 2012, 07:21 AM
Lightbulb People there have or had a AMD Bulldozer CPU, please help.
Hi.
Is there someone here that have tried to use Windows XP 32 or 64 bit on a AMD Bulldozer CPU?
I hope some of you can share the experience by use Windows XP on that cpu.
I will like to now if the AMD Bulldozer CPU can run on Windows XP without problems, and use the hyperthread and cores?
I answer because i can't drop off Windows XP jet, i love that classic OS if you know what i mean.
It is nice and easy to use, and also more fast.
And i want to upgrade my hardware very soon, when i have some things cleared
And what is best: AMD Phenom II VS AMD Bulldozer?
As i know they have almost the same technology exept the core technology, but AMD FX have a much larger cache. so I'm a little confused about what i shall select.
And if i use AMD Phenom II, what is the best Motherbard Socket: AM3 or AM3+?
All help is appreciated.
Old April 11, 2012, 07:37 AM
BlueByte's Avatar
I have run XP in a vm on a bulldozer opteron and it worked fine. Core parking won't work and you will get some inefficient threading going on with the cores since its a sudo hyperthreading. That being said unless you have a stop watch out I doubt you would notice on any legacy apps running on xp.
If you can get one on sale where it's $20-30 cheaper then the PII equivalent then it's a wash I personally think. They are a bit power hungry but I think bios updates and playing with power settings help a lot.
Old April 11, 2012, 09:35 AM
elmorejohn46's Avatar
IMO the Phenom II X4 is still the better chip .The Bulldozer was a big disappointment as far as I am concerned ,the reviews I have looked at show running them clock per clock the Phenom II is the faster chip.I know the bulldozer will over clock better ,but it needs the extra speed to even compete with the older Phenom II.I know you can get a 8-core chip pretty cheap ,but very few games make use of the extra cores and if you like classic XP games .I don't know what kind of system you are running now but I would'nt spedd a whole lot on a bulldozer system.If you just play games and want great performance and going to buy a whole new system then it is hard not to say go with intel.Socket AM3 and AM3+,the AM3+ has more features.Like I said I don't know what you are running now.But I have ran a Phenom II x 4 and a AM3+ with windows XP and never had any problems ,But the reviews ended me on the Bulldozer.I think the Bulldozer would be better as a server CPU the a gamer CPU.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
Old April 11, 2012, 10:31 AM
sswilson's Avatar
An AM3+ chipset is going to get you the latest motherboard options (like USB 3) regardless of what proc you decide to put into it.
As much as I rail against BD, I still give kudos to AMD for keeping the same socket for so long. Now, if only we could convince them to ramp production of PH II procs until such time as they've got a true replacement for them, they'll be back in my good books.
Old April 11, 2012, 11:36 AM
dandelioneater's Avatar
look for PII x4 or x6 chips, whatever you can find. Its not worth going with DumbDozer at this point.
Old April 11, 2012, 02:02 PM
Thans for all of your helps already
Well some of your have asked me what system i have now, and that is: Gigabyte G41MT-D3V Motherboard. Intel Pentium 4 E6700 (3.2 ghz, 2 cores, 2mb cache). Nvidia GTX 550 TI and Windows XP 64-bit.
And out of your experience, then i will take the Phenom II x4. It has a larche cache (2+6 mb), 4 cores, 3.40Ghz and Hyperthread Technology. I think that is much better then a Intel Pentium 4 E6700 Processor. But what do you say?
And i still don't know if i shall use a AM3 or AM3+ Motherboard, because i have heart of some people and read at the motherboards website that AM3+ should be fully compitable with AM3 CPUs. But that's not the same as it will run in equal speeds,
So what do you guys say about that?
AM3+ support sata 6 gb/s, USB 3.0, 1066MHz - 1866Mhz Ram, so i hope AM3+ motherbard can run AMD Phenom II with same compatability as AM3 motherbards, so i hope AM3+, so theoretically, it is best two buy a AM3 + Motherboard.
Tags
amd fx cpu , amd phenom ii am3 , windows xp
Bulldozer's best GPU? Pedwar Video Cards 22 April 11, 2012 10:02 PM
What is Bulldozer?? KSiG CPU's and Motherboards 16 October 11, 2011 01:42 PM
Why do people dislike OCZ? southbay Power Supplies 25 September 21, 2011 06:57 AM
People from MTL I need your help FlyingFish Off Topic 12 July 30, 2011 11:15 AM
What's with you people? Squeetard Off Topic 38 October 15, 2009 05:00 AM
