Old April 10, 2012, 03:55 PM
I only overclock my cpu. I mean it's so simple for a n00b like me. I don't go for anything nuts I am only at 4.4 and thats from following the ASUS ROG guide.
Old April 10, 2012, 04:36 PM
with msi even their cheap board has ram link or unlink settings
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
Old April 10, 2012, 07:59 PM
Silent_Avenger's Avatar
For me MSI is more of budget board. Out of the 2 MSI mid range priced boards I've owned both had flaky temp sensors and the one just wouldn't hold a decent overclock(could have just got a defective board). I'm sure MSI's top of the line stuff is good but their mid ranged I probably wouldn't buy unless I'm doing a build with no overclocking in mind(aka a parent's comp).
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old April 10, 2012, 08:07 PM
botat29's Avatar
Azrock start to make good interesting board at interesting price, if you look at the Z68 Extreme3 Gen3 , at $ 139 it as feature you find only in $ 200 Asus board.
Newegg.ca - ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Old April 10, 2012, 11:39 PM
Anandtech did a recent re-shootout of 990FX boards, which they covered from the top end/priced asus products, msi, gigabyte & the bottom end of things with the wildly popular sleeper biostar board. Msi boards where always middle of the pack in that re-shootout.
To me USUALY most of the user patterns I have seen over the forums for the last 8-10 yrs your looking at a either Gigabyte or Asus board ... then MSI ... then Biostar/AsRock/ECS.
Also to me, not ALWAYS is the most exspencive/popular brand name the best boards. I remember owning the Biostar TA690 board which was 1 of the best boards for a AMD 690G chipset which clocks cpu's the highest in oc's & was knockin off Asus boards 2x its cost.
Old April 11, 2012, 09:47 AM
elmorejohn46's Avatar
IMO MSI is not what it used to be ,I think ASRock is comeing out with good boards,they are build great and have great prices for what you get.But nearly all of the boards have some good ones ,some just need a bios update to get everthing working right,But some just don't overclock worth a darn.I like to check out which ones has good teck suppport.I had great luck with my Gigabyte EX58-UD5,it is over three years old and it is still going strong.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
Quality Headphones The Quicken Audio 6 September 30, 2011 11:17 AM
need a new quality MOBO john90009 New Builds 9 July 20, 2011 05:26 AM
Quality sub-$100 PSU suggestions? chrisk Power Supplies 19 November 22, 2010 01:27 PM
Different quality of USB cables? frontier204 Storage 3 March 5, 2010 03:52 PM
Powercolor Quality Edge Video Cards 7 February 27, 2010 06:21 AM
