Old March 28, 2008, 11:21 AM
Scart's Avatar
Default 14 seconds to boot
After installing my new ASUS M2N32-SLI Deluxe Wireless Edition, whenever I turn on the computer, it takes a full 14 seconds of fans spinning up before the computer beeps and boots up. On my old M2NPV-VM board, this process took all of 2-3 seconds. This is incredibly annoying and if anyone knows any solution to this I would be greatly pleased.
Old March 28, 2008, 11:24 AM
Do you have smart support enabled?
Old March 28, 2008, 11:30 AM
Scart's Avatar
I don't know what that is or where to change it.
Old March 28, 2008, 11:38 AM
It should be listed in the BIOS.
On mine its at the buttom of the screen.
And it say "Smart Monitoring"
Old March 28, 2008, 12:07 PM
t0m's Avatar
t0m t0m is offline
do you have a backlit keyboard? theres a thread on these forums about people having long boots/hangs at boot when using certain backlit k/b's with their new mobos...
nothing left and nothing right
Old March 28, 2008, 05:35 PM
Smart Support won't make a difference at all and is good to have turned on.
Old March 28, 2008, 10:41 PM
Scart's Avatar
Don't have smart support or a backlick keyboard.
In my bios I have AMD Live and Cool and Quiet, both of which are disabled.
AMD Virtualization (still not sure what it does) was enabled, but disabling it didn't change anything.
Old March 29, 2008, 01:54 PM
Finch's Avatar
did you try a new bios? or maybe try an other psu see if that help
Old March 29, 2008, 02:51 PM
sswilson's Avatar
What's your boot order? (Switch it to your HD first, and disable the floppy).
How do you have your HD(s) set up? Are they SATA or IDE? If you aren't doing RAID, have you disabled the raid controller?
Old March 29, 2008, 02:54 PM
sswilson's Avatar
Have you tried using the "optimum" settings in bios?
Is there a "boot timer" of some form in the bios that's pegged the wrong way? (There were HD initialization issues a few years back and some bios' were given a "boot delay" setting to allow the HD to get properly spun up before the bios "asked" it how things were going at boot).
