That hole on the i7-3820 I know it is were you can put a diode for temperture,but when putting Artic Silver paste on it will it hurt if it get down in it since it is made out of conductive paste.Or have they made sure that it will not contact nothing it should'nt .Or should I used artic silver Ceramique paste since it not supposed to hurt if it touches any contacts. |
I would say use a non-conductive paste just to be sure. There's many newer pastes out there other than AS5 which perform better and don't conduct electricity. |
I guess I will go with the artic silver Ceramique paste since it does not conduct eletricity.It supposed to be just as good as there silver paste .But I don't see why they put a hole in it if conductive paste could cause problems,but I rather be on the safe side.I have use both of them I just like the silver because it is thick and easier to work with.But my tempertures read around the same with either one of them.I have coolermaster paste that came with the heatsink but it is gray and looks like artic siilver. |
^^ i used ceramique a while back and found that it was rather poor at conducting heat. I had better temps with none of that paste on the heatsink/cpu. just my opinion... |
I have used Artic Silver evre since it has came out and always had good luck with it ,but I got some Artic siver Ceramique paste and to my surprise I had around the same tempertures as I did with the Artic Silver paste.I would rather use the plain Artic Silver paste but I don't know about the hole that is on the i7-3820 ,I was wondering if I get it down in that hole would it cause problems.I hope if anyone is reading this and has used a 3820 could tell me if it will hurt anything.Is is just a hole that is surrounded by something so no paste could get into the chip under the heat cap on it. |
I went to intel to chat to a teck and he relly did't know much .He said if I did not use the heatsink/fan that came with it I would be voiding the warranty.I told him that all the Sandy bridge-E do not come with a heatsink/fan.Then he said I need to use a stock intel heatsink and gave me part number ,I looked it up and it one of those that would not keep the processor cool even at stock speeds. |
I had real good luck with Artic Silver ceramique when I used it on my i7-920 and a Thermalright U120 Extreme and I had the same tempertures as I did with the Artic silver paste and it was not hard to take off like the AS paste can be. |
Yes I thought it was laughable when he said that I need to use a stock cooler.It was really funny because being a teck support ,you would think he new the new Sandy Bridge-E CPU's don't come with a heatsink/Fan.I will be useing the COOLER MASTER Hyper 212 EVO RR-R2 Continuous Direct Contact.I have seen reviews of people doing 4,8g with this cooler ,but all I want is the maxium overclock I can get at stock voltage,I am hopeing for at least 4.2g or I want go no higher then 1.35v .Even my old i7-920 ran at 4.2gigs from day one at 1.4v and it never got to hot.Three years with it and I never had no problems with my air cooler .I would think since this is a 32nm chip it should run cooler .I don't see why it has the same 130w TDP as the i7-3960X since it has two more processors and 5mb of more cache.The i7-3960x has 2.27 Billion transistors compared to 1.27 Billion on the i7-3820.The i7-920 only had 731 million transistors. |
| All times are GMT -7. The time now is 10:13 PM. |
