Old April 2, 2012, 02:32 PM
Default Why Does my computer Turn Off
Hello everyone i recently built my first rig and it shuts off randomly and sometime dosent turn on when i hit the power button. I dont know what is wrong. Is it the PSU? or something else. Please help.
SPECS:
CPU: FX-6100
MOBO: ASRock Extreme 3 990fx. Newegg.com - ASRock 990FX Extreme3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
PSU:Antec 750 High Current Gamer Newegg.com - Antec High Current Gamer Series HCG-750 750W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply
Old April 2, 2012, 02:41 PM
dandelioneater's Avatar
How are your system temperatures? -cpu heatsink seated properly?
Do you have another powersupply that you can test the system with?
Perhaps something is shorting in your case?
Any Blue screens? error messages? post codes?
Might be worthwhile to take the system out of the case to eliminate any possible shorting issues, re-seat cpu cooler, reseat RAM, then test the system with stock settings and examine your temperatures with HWMonitor. Make sure all your cables are pugged in too. If problem still persists, then power supply would be next to test.
I miss anything else to try right off the bat??
Old April 2, 2012, 02:46 PM
I dont overclock and the CPU stays at about 28 Degrees Celcius
Old April 2, 2012, 03:22 PM
sswilson's Avatar
This.........
Until you verify you don't have any external hardware issues (Case, USB ports, MB shorts, Power switch, etc..... ), it's almost impossible to point towards a possible motherboard/memory/PSU issue.
I had random power issues with my CH IV / 1090t build in the cosmos S that ultimately ended up being a problem with the power switch on the case... until I finally bit the bullet to tear down the WC and run outside of the case, I was convinced that something was going on with either my PSU or the OC on my rig.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC (Half Height) / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old April 2, 2012, 03:48 PM
Bond007's Avatar
Unfortunately there isn't going to be an easy answer. You will have to trial and error. It could be a loose wire (check all your connections, power supply cable fully plugged in, etc), a bad switch (button), power supply, motherboard, CPU...just about anything. The order I listed in is sorted simplest to more difficult to trouble shoot.
On a side note I actually had the power cable issue before. It seemed like it was fully in, but I was getting some random issues with power and when I unplugged and put it back in the back of the PSU it went in another 1/4" and I never had anymore issues.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old April 2, 2012, 06:41 PM
Try your psu in another computer to check if its the psu and use another psu in your computer.
if its not the psu...
it could be cpu overheating but then you said cpu is at 28 degrees..
could be the motherboard? like what Bond007 said, trial and error.
Old April 4, 2012, 12:12 PM
Painbringer71's Avatar
1st check all your connections like the 24 pin. Make sure they are seated properly. I had a 20 pin with the extra 4 that the 4 was not totally seated right. It looked like it was ok but needed an extra push to click in. It worked perfect until the graphic card needed extra power then wammo she shut off.
Old April 4, 2012, 05:02 PM
Sounds more like ram...
Unless it happends WHen a video card ramps up, The PS.
Old April 4, 2012, 05:56 PM
Bond007's Avatar
could be that as well. Try with one each stick of ram separately (another trial and error thing).
PC won't turn off... GT7R Troubleshooting 19 April 29, 2012 11:28 AM
[SOLVED] Computer turned on 1st time, but will not turn on again. tybeet Troubleshooting 12 September 8, 2010 06:14 PM
Led fans that you can turn off? Kovok Air Cooling 1 February 1, 2010 04:27 PM
Safe to turn on johnnyuterus Troubleshooting 15 January 5, 2009 08:27 AM
My turn to ask for help Cptn Vortex Troubleshooting 17 March 23, 2008 01:05 PM
