-   -   Gigabyte 990FXA RMA (http://www.hardwarecanucks.com/forum/cpus-motherboards/52897-gigabyte-990fxa-rma.html)
rfglass March 30, 2012 10:37 PM
Gigabyte 990FXA RMA
1 Attachment(s)
:offtopic:had to put together a system for a few weeks while my Gigabyte 990FXA UD-3 gets shipped away for RMA.Will not post,psu tested and good,ram good,gfx good,did all the usual tests everything is good just no post,had afew issues when starting it over the last few weeks,3 time bios was recovered from backup for no reason @ all.1 thing I did notice with HWmonitor is the NB peaked often over 200 degrees C but normally ran @ 30C.Has anyone heard of that as "normal"?anyways back to my core2duo for awhile :doh:my temp rig lol
Masteroderus March 31, 2012 01:05 PM
If it peaked @ 200 degrees I would wager there is something wrong with the temp sensor. Quite often they're cheap.
I had an old motherboard that asserted my motherboard was running @ ~-150c. I looked and I looked and I could not find a stead stream of liquid nitrogen....... XD
