Old March 24, 2008, 06:18 PM
Default E3110 now or Q9300 later
Like many others out there, I'm debating whether to go dual core now or Q9300 in a few weeks. I can wait, but will I see a improvement at all? I'm running a E2180 at 3.0 ghz and can last a while.
Old March 24, 2008, 07:02 PM
Cptn Vortex's Avatar
go with the E3110. Also, the Q9300 is going to be a bad overclocker, as it only has a 7x multiplier. You would need one heck of a Mainboard to get it going fast
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old March 24, 2008, 07:30 PM
werty316's Avatar
Ditto the Q9300 is not worth it.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old April 28, 2008, 07:47 AM
Sorry I went against all your suggestions and got myself a Q9300. It overclocks up to 3.5 ghz at 466X7.5. However, I need re replace the heatsink so I can run it at this speed 24/7. It loads at 79 on Prime.
Old April 28, 2008, 07:50 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Lol why ask if you dont take advice. I would have said 3110 too or Q6600/6700.
Old April 28, 2008, 10:10 AM
Rapid-X's Avatar
u sellin the old processor??
