Old March 21, 2012, 12:00 PM
core unlocker FYI is not to enable core that are functional such as the case with your FX chip, core unlocker was made for cpus which have cores "locked" so example the 960t could be unlocked to become a 6 core Phenom II, there has been a few cpu like this.
There is a way to lock specific cores with your cpu in the bios. It should be called core activation which should have manual, auto, disable as options, this allows cores to be "parked" but if the bios states your 8130 running 8 cores then it should be, but this might be a way to double check it :) Also by locking cores, it can help it hit higher clocks as well :P
Old March 26, 2012, 01:37 PM
sswilson's Avatar
Did you ever resolve this?
Old March 26, 2012, 02:21 PM
CMetaphor's Avatar
Quadfather
My bad, Yup. Resolved.
Twas the boot.ini. Setting cpus = 0 using freeBSD fixed it
Old March 8, 2013, 08:44 AM
Default Also helped by this - thank you!
Just wanted to post to say I was also helped by the advice in this thread - the "HOWTO: Get Windows 7 to detect your new multi-core processor - Microsoft Answers" link on the previous page fixed my problems with getting all eight cores of an FX-8350 detected. Big thank you to all.
Old March 8, 2013, 09:58 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Any time!
Task Manager - which logical cpus are hyperthreads Generic User #2 CPU's and Motherboards 6 November 13, 2011 06:29 PM
[FS] SOLD : Intel Xeon X3440 (I7-860), socket 1156, 4 cores / 8 threads plus TURBO Shftup Buy/Sell & Trade 0 August 4, 2011 10:48 PM
Priority in task manager Lamb HardwareCanucks F@H Team 1 December 15, 2009 08:48 AM
weird issue with task manager the_bandit87 Troubleshooting 4 May 25, 2008 01:49 PM
Tweaking Task Manager Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 8 February 6, 2008 11:13 PM
