Old March 20, 2012, 09:43 AM
Default P8P67-PRO BIOS settings
Hi everyone,
So yeah it's been a little sice I have my new rig. Haven't played that much with the BIOS since I am running it stock. I only disabled Marvell Controllers and one other thing I can't remember to speed up the boot since I only used certain specific SATA ports.
I never looked too deeply on this screen and always kept it at "normal". What the heck is the difference with all the options? I know the little polygon graph changes and gives somewhat a good idea of the effect but at a very high level. Do you think I should put in "performance" settings? Remember, no OC, I am running stock.
Mayoo
Gameplay > Graphics ... oh wait
Food > Gameplay > Graphics > Movies > Sleep > Work
Old March 20, 2012, 10:40 AM
Pabz0r545's Avatar
I tried changing mine to performance before to see what it did and it seemed as though it changed my bus speed from 100 to 103 which then gave me a tiny over clock but I seem to recall reading we are not supposed to change the bus speed on sandy bridge chips so I put it back to normal with a manual overclock.
Old March 20, 2012, 10:43 AM
SugarJ's Avatar
You can do a minor overclock on the bus speeds, but most systems crap out above 103 Mhz. If you had a K chip and a decent HSF, I'd tell you to try the Auto-OC funtion. On my wife's vanilla P8P67 it took her 2600K to 4.3Ghz without me touching a button.
BSOD + BIOS Settings Reset NineLives Troubleshooting 6 May 24, 2011 02:10 PM
Is it possible to overclock without the settings in the bios? andynerd Overclocking, Tweaking and Benchmarking 8 June 2, 2009 07:30 PM
Memory settings in bios Jonwall CPU's and Motherboards 2 February 6, 2009 02:32 PM
Please expert help fo bios settings evzonas RAM 2 August 6, 2008 04:01 PM
780i Bios settings help please Quetz Troubleshooting 17 April 27, 2008 01:23 PM
