Old March 24, 2008, 06:12 AM
Default SpeedFan and X38-DQ6
I like how Speedfan gives so many temp readings. However it does not seem to work with my Gigabyte X38-DQ6.
It is not even listed in the download config pages of Speedfan.
In any case the readings it gives me are out to lunch.
Temp1: 25 degC
Temp2: 24 degC
Temp3: -2 degC
Temp: 0 DegC
HD0: 24degC
Meanwhile Core Temp states:
Core #0: 45degC
Core #1: 43degC
HWMonitor confirms coreTemp
I really like to see more than just my core temps. Is there another program that works better with a DQ6 or does someone have a proper config for speedfan to work?
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old March 24, 2008, 06:19 AM
burebista's Avatar
Try latest beta.
Old March 24, 2008, 06:53 AM
Thanks burebists.
I was using Speedfan 4.33
Using the 4.34 beta 44 I can now see my cores but still have odd readings.
Note: The following temps are while running a Prime95 Torture Test with in place large FFT for max heat
Temp1: 25 degC
Temp2: 40 degC
Temp3: -2 degC
Temp: 0 DegC
HD0: 24degC
Core 0: 53 degC
Core 1: 50 degC
Old March 24, 2008, 08:35 AM
werty316's Avatar
For CPU temps use CoreTemp else use Everest or Gigabyte's monitoring app.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
