Old March 18, 2012, 03:04 PM
kyle_L's Avatar
Default Multi-CPU AMD Setup Help
well guys i want to venture into the multi-cpu amd side of things, any help on where to start would be great. it will be used for light gaming, video rendering and web surfing. my budget is 400+ what ever i can get for my 2600k setup. it will be air cooled for now and i would like it to fit in a fractal R3. where do you guys think i should start.
Gotta Love Timmies Coffee.
Old March 18, 2012, 03:21 PM
lowfat's Avatar
If you don't have a full tower case that can fit EATX then you are really stuck w/ C32 AFAIK.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 18, 2012, 03:41 PM
kyle_L's Avatar
the case is the last thing i am worried about.
Old March 18, 2012, 06:18 PM
Shadowmeph's Avatar
the setup for my FOlding box ( My sig) isn't to bad I could play any of the games that I had installed. I was actually a little surprised that I could play games at all being that my cpus are only 2gb 6128s
Old March 19, 2012, 08:33 AM
dandelioneater's Avatar
things to consider:
-2 proc amd boards can't overclock
-$400 + your 2600K gear probably wont get you that far. (maybe asus dual socket board and two octo-core magnys)
-gaming performance might take a hit since 61XX's only run at 2.0+ GHz.
-it would be good for video encoding/editing though if you can utilize all cores.
*It would make a great -bigadv linux folder though
Old March 19, 2012, 05:22 PM
kyle_L's Avatar
the budget is subject to change once i get my tax return, might be able to spend 1200 total.
Old March 20, 2012, 04:52 AM
MARSTG's Avatar
just pitching in with 2P experience : apparently Handbrake is not able to fully utilize 12 cores to the max when transcoding, i think it is optimized for just 8 from what i can see during transcoding. And yes no overclocking, or very difficult to achieve if any, most of the times not worth the trouble.
Bounty for Multi Monitor Setup Advice kurisu Display Units 7 July 2, 2011 03:46 PM
Crossfire Multi-monitor setup? nzorov Video Cards 4 April 16, 2010 08:33 AM
New to multi-GPU folding, quick setup questions... Caldezar HardwareCanucks F@H Team 33 February 7, 2010 12:06 PM
Multi Channel Setup phantom_jo Audio 1 December 25, 2009 12:36 AM
Multi GPU Setup help SugarJ HardwareCanucks F@H Team 12 November 18, 2009 05:57 PM
