-   -   Quick switches on motherboard (http://www.hardwarecanucks.com/forum/cpus-motherboards/52506-quick-switches-motherboard.html)
count March 17, 2012 12:34 AM
Does the turn on power switch on the GA-X58A-UD5 motherboard serve the same purpose as shorting the two prongs on f.panel. Also for future ref. is this the reason that the switch is put there.:canadianwave:
enaberif March 17, 2012 08:49 AM
Yes
Yes
Its essentially a test button
count March 19, 2012 12:15 AM
Thank you
Thank you for responding
KaptCrunch March 19, 2012 04:38 AM
prevents from shortting out other stuff the switch onboard, makes easy start
