Old March 22, 2008, 08:15 PM
Default DFI Lanparty LT t2rs not booting w/ e8400
Hi,
I recently bought parts for a new system based on the DFI Lanparty LT t2rs motherboard and an Intel Xeon E3110 CPU (which I hear is identical to the Core 2 Duo E8400). I put it all together this morning and the thing won't boot at all. When switched on, it spins up all the fans for a few seconds, during which nothing appears on the display, and then shuts down. Then, a couple of seconds later, it tries again, with similar results.
The diagnostic LED display on the motherboard lights up random segments of the digits instead of comprehensible numbers, and usually it's different on every boot.
I've tried re-seating the RAM and video card and a CMOS reset. I tried taking the CPU out of the motherboard and booting CPU-less, and instead of cycling the boot as before, it spun up and stayed on. Still, nothing on the display.
I've read that the DFI motherboards need a BIOS update before they support the 45nm CPUs, but I don't have another LGA775 CPU available with which to flash the BIOS. Is it likely that this is the problem, or, given the symptoms, is there something wrong with the actual hardware?
Old March 22, 2008, 09:17 PM
Cptn Vortex's Avatar
which chipset it that? X38 or P35?
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old March 22, 2008, 09:18 PM
Sorry, it's the DFI Lanparty LT P35 T2RS, so P35 chipset.
Old March 22, 2008, 09:43 PM
Hmm... it should work. It is always best to throw on the latest BIOS though. I would definitely suggest borrowing a older C2D from someone and flashing the BIOS, or bringing your board to a local tech shop and having them flash it for you.
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Old March 22, 2008, 09:46 PM
A local tech shop -- would a Radioshack be able to do that, or what kind of tech shop should I look for?
I've since read a post by someone who had similar boot-shutdown-reboot-etc problems with this setup and it was solved by a BIOS flash, so hopefully I'll be able to track down a CPU.
Old March 22, 2008, 10:17 PM
No, radioshaq will not. You need a PC store, like NCIX or frontierpc that has a service depot. Where are you located?
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Old March 22, 2008, 10:37 PM
JD JD is offline
Maybe not all your power connectors are in securely? Also try with a single stick of RAM (if you are using more than one).
Another thought, try running it outside of the case as it may be shorting out.
Old March 22, 2008, 11:17 PM
turtletrax's Avatar
My advice is swap procs (which you dont have.Any friends with any?) and flash. Then do a battery removal Clear CMOS overnight. Boot with the least amount of hardware possible and out of the case would be best.
It took me two days the get my P35-T2R to POST, but man am I glad I did not send it back for RMA. Best board I have ever had. Main thing is perseverance with DFI. Or is it stubborness?? I DK, but keep at it. PM me tomorrow if you still have issues ;)
Damon
"It's time to kick gum, and chew ass. And I'm all out of gum."
Dick Kickem
Old March 23, 2008, 05:55 AM
Thanks for all the advice.
I'm located in central North Carolina, USA. Any location near Chapel Hill, Raleigh, or Durham would be reasonable.
I'll try it outside the case. I'm using OCZ Reaper RAM, and I've already tried with only one stick. Are the various DIMM slots different? They're Green-Yellow-Green-Yellow, and I've been trying using the two green slots simultaneously.
Old March 23, 2008, 07:05 AM
ebdoradz's Avatar
DFI board has always been picky for ram and PSU
Could you plz list all your PC parts of your computer.
also make sure you have a 24pin PSU has long has a 8pin EPS plug correctly, + the 2 floppy plug above the 2 upper PCI-e x16 slot
if it still refuse to boot i would redirect you to the DFI club, the official DFI support forum
DFI Club Global Support Forum - Powered by vBulletin
you could always take a look at that sticky thread on the dfi board about the P35
P35 LT/UT - "LP" P35 Info AND Performance Tweaks - DFI Club Global Support Forum
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
