Old March 10, 2012, 01:32 AM
Bungwirez's Avatar
Default XFX 680i LT - still rockin
bought 2008. Q6600. 1000's of hours gaming.
turned it over to the Mrs for YouVille/Browsing/ShoppingCart/etc.
so its finally showing her age and the north/south bridge fans are going.
anyone recommend some heatsink/fan replacements?
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old March 10, 2012, 05:59 AM
Antec Spot Cool if you don't have to hunt down specific fan sizes - Antec Spot Cool Adjustable System Cooler Blue LED 3 Speed 2000-3000RPM 23-33DBA 15-22CFM - DirectCanada
If you don't mind hacking with your choice of adhesive, Scythe's 40mm Mini Kaze is quiet even at full speed: Scythe Mini Kaze Ultra 40MM Silent Fan 20MM 3500RPM 4.8CFM 19.5DBA 2PIN 3PIN - DirectCanada
If you have thermal adhesive (not compound) you could likely replace the southbridge heat sink with some old piece of metal that sticks out a little more and have it cooled by your case fans.
Rendered.......( aka die 680i die) BrainEater Case Mods, Worklog & Gallery 108 May 28, 2013 06:33 PM
RMA 680i howpet CPU's and Motherboards 10 May 14, 2010 08:08 PM
680i = JUNK nckid4u HardwareCanucks F@H Team 15 May 19, 2009 06:48 AM
Opinions on XFX 680i LT slugbug CPU's and Motherboards 14 December 21, 2007 04:29 PM
evga 680i , which one ? Jim CPU's and Motherboards 3 August 28, 2007 11:03 AM
