  #21 (permalink)
Old February 24, 2012, 04:18 PM
Originally Posted by Eldonko View Post
SB-E is not good for gaming?
Not compared to the 100 dollar cheaper 2500k?
At every gaming benchmark in this test, the difference between the 2500k and the i7-3820 is laughable at best.
Certainly not worth 100 dollars and that's before we take the motherboard costs into consideration.
If we were to chose the Hardwarecanucks motherboard of the year 2011 and the runner up, we'd be looking at a whopping 300 dollar difference.
For maybe .4 FPS increase in a game, IF you leave hyperthreading off?
All that money would be better spent elsewhere.
  #22 (permalink)
Old February 24, 2012, 04:28 PM
-still waiting on retail stepping reviews ,updated micro[M1] code in the mb bios ,
-looking for some 3820 max. stable oc with 1.4v to compare to sb\1155. [hint hint ]
-checking the asus mb's bios for the RIVE & RIVF , it looks like they only have a starter bios with M0 [es] support listed for the 3820 .-sad
  #23 (permalink)
Old February 24, 2012, 04:44 PM
-you have a point ,
but as a gaming rig , do you know for sure down the road if 2 gtx 780's sli or gtx 880's sli won't be crippled by x8,x8 pci-e 2.0 ?
-per net gtx 780 =2 x 580
-next flagship gtx 880? =4 x 580.
-alot of people don't upgrade cpu's ,like gpu's every 6 months ,some like me still have x58's that are slower but not crippled like the sb\1155 mb's.
-x79 is the replacement for the x58 ,should not be crippled for 3 yrs. maybe, sb\z68 is toast come april.
  #24 (permalink)
Old February 24, 2012, 04:47 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Picking up a 3820 retail and installing in RIVE this evening. Will post results when I get a change to OC.
  #25 (permalink)
Old February 24, 2012, 05:35 PM
werty316's Avatar
I plan on upgrading to this chip however availability is crap; everywhere I look has it sold out :(
Anyone have a theory as to why these chips are in short supply?
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
  #26 (permalink)
Old February 24, 2012, 05:49 PM
Eldonko's Avatar
Intel has been really bad on retail distribution for LGA2011. Even 3930K is difficult to find and it came out 3 months ago. I just got mine at mem express and it was the only one they had.
  #27 (permalink)
Old February 24, 2012, 06:02 PM
werty316's Avatar
Hopefully there'll be a larger supply once my other parts arrive.
  #28 (permalink)
Old February 24, 2012, 06:18 PM
Bond007's Avatar
Great review. I think its the way to go if you will use it in one of the few scenarios that it is advantageous, or you plan to buy a high end board already.
  #29 (permalink)
Old February 25, 2012, 05:45 AM
-you have a point ,
-you have a point ,
Asus P8Z68-V Pro/Gen3 has pci-e 3.0.
Hard Choices: CPUs | Rock, Paper, Shotgun
Get to reading gentlemen, you got some catching up to do.
Then spend your saved money elsewhere.
You're welcome.
  #30 (permalink)
Old February 25, 2012, 06:38 AM
JD JD is offline
You're welcome.
It isn't actually running PCIe 3.0 until Ivy Bridge drops. Sandy Bridge doesn't have capabilities for PCIe 3.0. This is also under the assumption that the way board manufacturers have implemented the PCIe 3.0 switching will be compatible. I believe Intel has the Z77 chipset following Ivy's launch which will likely be the "better" choice for PCIe 3.0/USB3.0 users as it will all be natively designed.
Sandy Bridge E is the only way to get PCIe 3.0 currently. I surely wouldn't by a Z68 board with hopes of running PCIe 3.0 on it properly, but that's just me.
Intel Sandy Bridge Core i5-2500K & Core i7-2600K Processors Review Comment Thread SKYMTL CPU's and Motherboards 52 November 6, 2011 09:21 AM
Intel Core i3-2120 & Core i5-2400 Processors Review Comment Thread SKYMTL CPU's and Motherboards 9 July 19, 2011 07:17 AM
Intel Core i3-540 Review Comment Thread SKYMTL CPU's and Motherboards 17 January 11, 2011 12:24 PM
Intel Core i5-655K & Core i7-875K Unlocked Processors Review Comment Thread SKYMTL CPU's and Motherboards 23 May 29, 2010 05:20 PM
