Old March 19, 2008, 06:32 PM
Default HELP!!!
MY NEW COMPUTER BUILT TODAY NOT BOOTING UP AT ALL
I've checked every connection twice and it's still not booting at all
seems dead period
no sound no power
nothing
Old March 19, 2008, 06:42 PM
llama_egg's Avatar
Now, I'm just trying (hard) to sound like a jackass here, but we kinda need...you know...a tad bit MORE INFO! So far all we know is that you have a new computer, and it doesn't boot, which does not help pinpoint the source, and thus leaves many paths which could lead to the fiery pits of hell which is housing your problem. XD
Bah, sorry, I've just had one of those days, but in all seriousness, what parts are you using, does the PSU power on, is anything getting power
, ext ext. The more info you can give, the easier it will be to find out the problem! :D
Old March 19, 2008, 06:44 PM
3.0charlie's Avatar
Fans spin? HDD noises?
We need full specs to help you.
Hydro-Quebec is salivating...
Old March 19, 2008, 06:46 PM
Babrbarossa's Avatar
Crappy! What level of experience are you (just so we don't make suggestions that are insultingly obvious)
Do you get any sound alamrs, When my computer was not abble to post it did the infamous 'biiiip bip bip' alarm. Wich means memory problem. Turned out that the asus m2n sli deluxe is not compatible with OCZ ATI corssfire edition memory(wish i had known, the memory is for sale)!
So yes we do need more info to help you out.
Old March 19, 2008, 07:08 PM
no no sound no nothing
just tested the psu
works on another motherboard
i have a p35 GA DS3mobo
E6750
em2 5-5-5-12 2x1 gig ram from mushkin (1.8V)
1 dvd-combo samsung
1 dvd rom
250GIG HD SEAGATE BARRADA
could it be the pin plug ins
Old March 19, 2008, 07:10 PM
NOW The case is a elite330 from cooler master
and the pins don't give + or - could that be the reason
Old March 19, 2008, 07:16 PM
sswilson's Avatar
Could be.
Unplug the case headers from the motherboard, and use the tip of a jeweler's screwdriver to short out the "power on" pins on the motherboard header (where your power switch jumper from the case is supposed to go).
Old March 19, 2008, 07:19 PM
3.0charlie's Avatar
Did you plug the 12V connector, the one with 2+2 pins that is located close to the CPU?
Old March 19, 2008, 07:22 PM
Unplug the case headers from the motherboard, and use the tip of a jeweler's screwdriver to short out the "power on" pins on the motherboard header (where your power switch jumper from the case is supposed to go). how is this done.?/
yes i have pluged that in
