Old February 19, 2012, 08:14 PM
Default Cut the 8150 in half?
Hey guys, I have an AMD FX-8150 and I was wondering, would disabling 1 core in each module make it faster? Would Windows schedule loads a lot better if I did this? I saw a post saying it increases performance 20% on some benchmarks so I was wondering, would this actually make a difference? I use my system mostly for gaming so maybe I'd get higher FPS or something, I do have an ASUS Sabertooth 990FX mobo so I can turn cores off If I need to. So yeah, what does disabling Core 1, 3, 5 and 7 do performance wise?
Old February 19, 2012, 08:25 PM
I doubt it would help all that much, but at the least you could probably pull a bigger overclock out of it and get more performance that way.
Old February 19, 2012, 08:38 PM
Most of what I read mentions that you only want to disable cores to achieve a higher overclock. You could disable 4 cores and overclock higher which would perform better in some games and benchmarks, but in my opinion is not worth the time and effort unless you get your rocks off on high benchmark numbers.
fx 8150 weird cpuz lol gingerbee Overclocking, Tweaking and Benchmarking 7 December 29, 2011 07:03 AM
What would be a good MoBo for the AMD FX-8150 ern88 CPU's and Motherboards 7 October 10, 2011 04:47 PM
teasers FX-8150 oc'ing terrybear Press Releases & Tech News 9 September 15, 2011 04:47 PM
half hight vid card with half hight back plate tzetsin Video Cards 11 June 17, 2009 08:00 PM
