Old February 17, 2012, 02:55 PM
Default pci 3.0??
Is the ASUS 990FX Sabertooth mobo gonna be able to run the new gpu's from nvidia when they come out. I know stock they are not PCi 3.0. Will that just take a bios update? Thanks for all the help!
Old February 17, 2012, 03:08 PM
maverick_brent's Avatar
yes. No problem, pcie 3.0 is backwards compatible with pice 2.0
Old February 17, 2012, 03:20 PM
i would like to run the card at 3.0. Does it only take a simple bios update to make the slot 3.0 if they r not already
Old February 17, 2012, 05:22 PM
Negative. Either the board is PCI-E 2.0 or 3.0 and even if its 3.0 it won't make any difference with the new cards.
Heck the LATEST high end cards don't saturate 2.0.
