Old February 16, 2012, 08:49 AM
Default i7 2700K
I'm just curious what people think of these how are they for overclocking etc..
How do they compare to the very well spoken about 2500K or 2600K?
Thanks in advance for any feedback!
Comp1 (Mine) : ASUS P9X79 LE, 3960X, 16GB Corsair Vengence 1333, PNY 770 4GB, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : ASUS Sabertooth P67, i7 2700K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, EVGA 660, Corsair 1000HX, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Gigabyte 770, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 120
Old February 16, 2012, 09:30 AM
Silent_Avenger's Avatar
TBH save your money and get a 2600k. From what I have heard the 2700Ks don't overclock much higher at all they just have a faster set clock speed.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old February 16, 2012, 09:47 AM
francisw19's Avatar
^^ Agreed...I've heard the same thing. I'm not sure if it's true or not, but some people have mentioned the 2700K has a higher maximum multiplier than the 2600K. If true, this really isn't an issue unless you are going for some very extreme overclocks - for day-to-day use, the 2600K is a great chip.
Old February 16, 2012, 12:43 PM
Is max multiplier based on the chip or the board?
Because my 2600k had a max multi of 56 on a gigabyte p67a-ud4 but has no limit to it's multiplier on my EVGA z68 FTW.
Old February 16, 2012, 01:58 PM
both
sometimes you get higher multi with a mive
56x is a good cpu
many 2700x cant hit over 51
your cpu has a limit lol
max multi is what you can boot into windows with;)
2700ks are not better than 2600ks
unless you run stock
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old February 16, 2012, 03:14 PM
Bottom line, it's still a crap shoot. If your goal is 4.8 GHz, 2600K or 2700K should get you there with reasonable volts.
Some folk on XS.org found early 2700K's to be worse than 2600K's, but they are pushing >51x multiplier.
FWIW my very early batch of 2600K (L040B purchased on launch date) OC's about the same as a late batch 2700K (3122C retail edge) -> 4.8 on 1.42ish volt, 5 GHz on 1.46ish volt with modest cooling (~80-85C on full load with LinX AVX). My 2700K actually runs a little bit cooler while require a slightly higher voltage (+0.1V)
heatware
Old February 17, 2012, 03:49 PM
I ended up getting it currently have it at 4600
CPU-Z Shows = 1.42v
CORETEMP Shows = VID : 1.3611v
Temps with prime95 are about 75ish this is with an antec kuhler 920 - debating getting H100 to see how much difference it makes!
Are these temps and volts good?
Old February 17, 2012, 03:51 PM
maverick_brent's Avatar
CPU-Z Shows = 1.42v
I cant quote on the 2700k exactlly, i have the little brother 2500k currently at 4.6ghz, 1.36v temps dont hit 60c with prime, on a hyper 212+..have done 9hrs stable on that...i wouldnt say yours are to bad at all, not spectacular,m whats the rest of your system?
Old February 17, 2012, 03:57 PM
See my sig :) Also what speed you running at all i see is .6? :)
Old February 17, 2012, 04:40 PM
If it's a good chip you should be able to get 4.6 at 1.35v depending on the board's Vdroop.
I find with Vdroop disable voltage can be so solid I've gotten utterly ridiculous clocks(5.5+ on 15c water).
i7 2700K & DP67BG trayton Price Check 1 February 16, 2012 08:59 AM
i7 2700k, 560 ti, and... noname2020x New Builds 10 December 29, 2011 10:51 AM
i7 2700K released yycraven CPU's and Motherboards 10 October 25, 2011 04:31 PM
Intel Leaks i7-2700K onethreehill CPU's and Motherboards 9 September 12, 2011 03:54 PM
