Old March 17, 2008, 08:50 AM
Synth's Avatar
Default Upgrade path possibilities ...
Alright guys, heres the dilemma.
As you can see in my sig, I have 2 systems : 1 SLI ready and the other is a single card (Blood Iron).
For a casual gamer like myself (with a 22inch screen), would it be worth it to swap systems (Intel for HTPC & AMD for casual gaming and websurfing) and buy a 8800GTS 512mb for the SLI ready AMD system…?
With that cpu, clocked up to 2.8ghz+, would I get reasonable fps in my current games (CoD4, UT3, SupCom) and possibly, later on with a second GTS512 for SLI, future games…?
I foresee prices coming down, so going nVidia in my mind would be worth it.
I don't plan on going quad core any time soon either…
Any input ?
Old March 17, 2008, 08:54 AM
CMetaphor's Avatar
Quadfather
Why not get an 8800GT? much cheaper and better performance.
Old March 17, 2008, 09:33 AM
Synth's Avatar
Than a G92 512mb GTS ?
Old March 17, 2008, 09:53 AM
Cardboard box with DSL's Avatar
The Gts 512mb only yields a 5%-10% performance increase over the GT 512mb, $80 isn't too much, but for the increase that you will see, it would be better to grab a GT and put good cooling on it and OC the sucker.
Old March 17, 2008, 09:54 AM
Babrbarossa's Avatar
I would probably go with the GT- you can get them for 170 bucks now- much better price/preformance ratio
Old March 17, 2008, 10:25 AM
Synth's Avatar
Alright, sounds like a plan for the 8800GT...
Now about using the 570SLI and the 3600+ Brisbane, can I expect decent performance, if OC'ed to 2.8ghz + ?
Down the path to the Dark Side...my first ever WC build! zlojack Case Mods, Worklog & Gallery 100 May 9, 2008 09:19 PM
upgrade or full? Jarod_g29 O/S's, Drivers & General Software 5 March 12, 2008 09:02 PM
Future upgrade... omgwtf CPU's and Motherboards 17 December 30, 2007 04:34 PM
should I upgrade yycraven CPU's and Motherboards 13 December 10, 2007 06:10 PM
Vista Upgrade Path Gav O/S's, Drivers & General Software 14 March 30, 2007 01:43 AM
