Old January 30, 2012, 05:33 PM
Default 990FX RAM COMPATIBILITY?
i have a asrock 990fx mobo and was wondering if you can mix and match RAM. For example in 2 of the slots have 2gb sticks and the 2 other slots have 4gb sticks?
Please help
Old January 31, 2012, 09:19 AM
norfolk's Avatar
My ASUS Crosshair V is very picky for ram, and with that said I ended going to the ASUS site and checked the QVL list and bought accordingly,All 4 slot"s on mine are populated with the same densities .You should check with the mobo manufacturer just to be sure.My Crosshair runs perfect considering all the problems guys are having.(Knocks on WOOD).
ASROCK 990fx... KSiG CPU's and Motherboards 1 January 30, 2012 02:49 AM
Crosshair V vs Sabertooth 990FX Masteroderus New Builds 6 January 10, 2012 10:12 PM
Asus Sabertooth 990FX Issues lechumbl CPU's and Motherboards 19 November 22, 2011 08:45 PM
990FX Upgrade - XFire or SLi? Caldezar New Builds 126 July 13, 2011 06:19 AM
990FX with Phenom II x4 980 vs i5-2400 Comparison PerryC Reviews & Articles from the Web 3 May 30, 2011 03:09 PM
