Old January 26, 2012, 10:42 AM
Default (ASUS) Bios is remembering TPU settings after Tpu is disabled
This pictures pretty much says all... http://i.imgur.com/VBNIm.png
History
1. I7 not knowing how to overclock I flipped the TPU switch on ASUS Z68 motherboard.
2. It put me up to 4.5 Ghz at 1.3+ volts
3. Didnt like the settings, so I returned to default (plus tried some manual overclocking)
4. That didnt work and timid to mess up my cpu I went back to stock
5. So went to stock Now if if I go into advanced bios its says target speed 3.8 Ghz, but after it boots me up it goes back to 4.5 Ghz as in the pic... I want to start over,
I used my jumpers to reset bios... I have not removed battery...
Any other suggestions? Should I do an RMA?
Old January 26, 2012, 10:47 AM
Eldonko's Avatar
Hardware Canucks Reviewer
You sure TPU switch is fully off?
Old January 26, 2012, 11:06 AM
Silent_Avenger's Avatar
Shutdown your comp unplug the PSU, remove the cmos battery, press the power switch and leave it for 30min. That should hopefully clear everything by depleting any excess power on the board.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old January 26, 2012, 11:20 AM
Yea the switch is off and no more LED light
Old January 26, 2012, 11:23 AM
Could the Asus AI Suite II I have installed be affecting this as well?
Old January 26, 2012, 12:24 PM
Birk's Avatar
yes yes it could.
-- Main System --
THERMALTAKE Chaser MK-1
ASUS P8Z68-V Pro / Gen3
INTEL Core i5 2500K @ 4.5ghz 1.35v
- XSPC Raystorm
DIAMOND Radeon HD 6950 2gb @ 840/1325
- AQUACOMPUTER AquagrATIx Full cover Block
CORSAIR Vengeance C9 16gb (4x4) 9.9.9.24
OCZ ZX 850w Gold
WD 320gb, 1Tb, 500gb
LG 22x Super Multi DVD
Old January 26, 2012, 04:57 PM
I unplugged, I used my jumpers to reset the bios, I took out the battery, deleted any asus software from my pc and still getting these results... Should I file an RMA? http://i.imgur.com/VBNIm.png
Old January 26, 2012, 07:30 PM
Eldonko's Avatar
Switch TPU switch to the on position, clear cmos and try it one last time. Yes I said on..
Old January 26, 2012, 07:56 PM
Have you tried not clicking on asus optimal and just use the normal settings in easy mode? Save and reboot see what that does.
Old January 26, 2012, 09:22 PM
This is where I might be too critical. I have that clicked right now, and I am at stock speeds with a maximum of 3.5 Ghz.
And where should walk away happy that its fixed. But at the same time I have the fact the optimal settings is doing what its doing.
To me it does not make sense and I am 100% certain it never went to a manual setting.
If i remember correctly before all this happened.
Normal - 3.5 Ghz
Optimal 3.8 ghz
I dont want to RMA and find that this is what the board actually does...
Asus P8Z68-V: What BIOS settings are enabled/disabled by TPU/EPU switch? Tempstar CPU's and Motherboards 15 November 22, 2011 05:02 AM
Is it possible to overclock without the settings in the bios? andynerd Overclocking, Tweaking and Benchmarking 8 June 2, 2009 07:30 PM
Memory settings in bios Jonwall CPU's and Motherboards 2 February 6, 2009 02:32 PM
Please expert help fo bios settings evzonas RAM 2 August 6, 2008 04:01 PM
780i Bios settings help please Quetz Troubleshooting 17 April 27, 2008 01:23 PM
