Old January 20, 2012, 07:29 PM
Default 2011 pci e 40 lanes
Hello
So to get 40 lanes, 4 cards are needed? 16x8x8x8 or is it 16x16x8 (LGA 2011)?
MB specs on the x79 show 16x8x8 for 32 lanes as old LGA1366.
Old January 21, 2012, 09:01 AM
if I'm not mistaken some lanes are taken up by additional chips on the motherboard such as additional lan, sound, USB controllers, sata controllers. Which may be why you get 16x8x8
Old January 21, 2012, 10:46 AM
It also depends on the motherboard you have, for example I believe the ASUS IV Rampage X79 will do 16x 8x 16x in a 3 way config or 16x 8x 8x 8x in a 4 way config.
Old January 21, 2012, 06:04 PM
there is no difference between 16x, 8x the cards run only as fast as the slowest lane so if you are tri sli at 16x, 16x, 4x it is the same as 4x, 4x, 4x. You don't need to fill the lanes and it depends on the mother board what the lane distribution is.
Old January 21, 2012, 10:17 PM
Thank you for the input.
2011 And Still Sharing Lanes? Luay79 CPU's and Motherboards 17 January 4, 2011 10:30 PM
GPU-Z only showing x8 PCI-E lanes?? homer98 Video Cards 34 August 28, 2010 01:10 PM
PCI Express And SLI Scaling: How Many Lanes Do You Need? Luay79 New Builds 1 August 9, 2010 01:47 AM
Running low on PCI lanes Toyoracer Reviews & Articles from the Web 0 March 25, 2010 08:27 PM
pci-e lanes troubles phantom_jo Troubleshooting 6 May 13, 2009 03:02 PM
