Old January 17, 2012, 11:59 PM
Default Phenom II x4 960T?
will a phenmom II x4 960t bottle neck my gtx 560 ti
600w psu
8 Gb ram
Old January 18, 2012, 12:04 AM
supaflyx3's Avatar
No, even less so if you can unlock the 2 extra cores.
Old January 18, 2012, 12:08 AM
thanks man now i gotta go watch youtube tutorials on how to do that
Old January 18, 2012, 06:55 AM
Depends on your motherboard, ASUS boards you go into bios, under cpu extras or some such thing, it is known as core unlocker, it will work or not, you can tell by the bios/cpu-z now calling your chip something else other then 960T, the unfortunate side is, you usually lose a chunk of OC headroom in the process.
For a single gpu, the 955BE and 960T are about the same, I have 0 issues feeding my 6870 overclocked, and when I do OC the chip, my card runs like a ferrari :P
So as far as bottleneck, I doubt it, you want you chip to feed the system as best it can, up the cpu/nb speed.
best calculation to use for this is.
base memory speed x3=cpu/nb desired speed.
example
ddr3 1600 base speed=800 800x3=2400 so you want the lowest speed for cpu/nb or memory controller aka IMC to be 2400mhz.
Though do be sure to leave the HT speed as close to stock as possible, mine is 2000Mhz on the HT, no matter how far I overclock, the performance benefits for having HT up there is not worth it, and can actually hurt it performance/stability.
So fast cpu base speed, fast cpu/nb, fast memory at good timings, fast gpu clocks, default HT speed.
Also ddr3 1600 at looser timings i.e 9,9,9,24 is generally better then 1333 at 7,7,7,21 extra bandwidth is better then tighter timings in virtually everything, especially when doing memory intensive tasks, but, loose timings high speed, say ddr3 1600 at 10,10,10,24 well then the tables flip again :O
If you have option in bios, make sure memory is set to unganged mode as well, sometimes known as DC mode.
Your chip if you decide to do so, should be able to overclock to 3.8-4.2Ghz with decent voltages, decent temperatures, with a decent cooler, that will make sure it flies :)
Old February 14, 2012, 03:59 PM
Stop creating so many threads. Ask everything in one thread. Cluttering up the board bro.
FX-6100 VS 1055T VS 960T phantom_jo CPU's and Motherboards 4 December 31, 2011 06:49 AM
AMD 960T sees the light of day as a retail chip Bond007 CPU's and Motherboards 13 October 18, 2011 01:19 PM
Phenom X4 9950 -> Phenom II X6 1055T? frontier204 CPU's and Motherboards 7 July 15, 2010 03:51 PM
AMD Cancels Retail Phenom II X4 960T Thuban Quad Core Processors geokilla Press Releases & Tech News 17 May 13, 2010 10:08 PM
AMD prepares its Phenom FX, Phenom X4 and Phenom X2 lineups Babrbarossa Press Releases & Tech News 1 May 4, 2007 07:38 AM
