i7 3930K only recognized as 4 cores (Solved) Hi guys, I just realized that my 3930K is only recognized as 4 cores and 8 threads... CPU-Z shows only 4 cores, same thing with core temp. What's going on here? Is this normal? |
Did you just get a new cpu in an existing build? uninstall all processors from device manager and reboot. |
I did that, It installed new driver, restarted, and it still shows 4 cores =( |
Bios at latest version? What Board? |
I haven't checked the bios version yet, it's on Rampage IV Extreme (on my system specs). Would bios version effect it this much? it's a pretty recently released board though Edit: Just updated to the latest Bios, and it still shows 4 cores only Current bios is 1101 |
best guess, check bios settings. Meny bios let you turn on\off the Hyper-threading [IMG]http://www.************/images/articles/1323429127PAlf6ifPah_3_21_l.gif[/IMG] |
The question is, why would I want to disable hyperthreading? Currently I only have 4 cores detected, and 8 threads, where I should have had 6 cores and 12 threads.. Anyone else got any problem with this? I have actually seen a youtube video showing the same version of CPU-Z with 3930k showing 6 cores and 12 threads. Edit: here's the youtube link Sandy Bridge-E i7 3930K Cinebench 10 - stock clock - YouTube I've had all cores activated on bios too http://i1156.photobucket.com/albums/...frost/cpuz.jpg |
Does task manager show 4c/8t as well? |
Are any cores disabled in BIOS? Try clearing the CMOS and try again. What does a Linux Live CD tell you? You can get the number of cores in any Linux by typing Code: cat /proc/cpuinfo |
If you run cinebench or AIDA 64 cpu queen does your cpu score properly or are your scores down from what it should be? |
| All times are GMT -7. The time now is 10:51 PM. |
