Old January 14, 2012, 01:49 AM
Default Help me Choose!!
i'm building a pc and choosing between Asus Maximus IV GENE-Z Z68 chipset ans Asus Maximus IV Extreme P67 chipset.. I'm gonna use 2 way SLI..
What mobo would you recommend?
Old January 14, 2012, 03:28 PM
ASUS P8Z68 V or V-pro, I myself prefer a full size motherboard, less likely to have spacing problems.
The P67 boards, the only one that I will recomend is the ASUS Sabertooth P67 rev 3, excellent board, 2 of my buds have them, they love em(though I would use it without the thermal shield as ASUS says you HAVE TO use the extra fan which doesnt come with it, so I would just take the thermla shield off :P)
You are overpaying for the ROG boards for the most part, when you can get a 99% as good motherboard for far less $ in the ASUS lineup. Generally -E -pro are better then deluxe :)
The Gene is apprently an excellent board, the maximus you listed, is quite $ obviously, and apprently had performance issues with it in a few different ways, such as sata flaking out, ethernet connectivity issues and such.
Me, I would go with the 3 I listed over the 2 you chose, but, if it HAS to be those 2, then Gene it is.
Old January 15, 2012, 05:46 AM
How about the ASUS P8Z68M-PRO?
Old January 15, 2012, 10:18 AM
a35599's Avatar
I built my sons computer using the Gene, I think it is a great board. He does alot of gaming and the on-board X-Fi is a great touch. The M-ATX format is great as well, put it in a Coolermaster Storm Enforcer fits nicely in that case and looks sharp on the black background.
It is great for overclocking as well, bump up the CPU 25% and is stone stable on Corsair Hydro 50 cooler.
The option for SLI or Crossfire is also great. (although I lean primarly to SLI).
Old January 15, 2012, 10:54 AM
If i had to pick id go with the Asus maximux IV Exteme p67 chipset,i love monster size E-atx bords when i can find em.
Don't know about the chipsets,id have to research.......don't feel like it atm.
You know bigger is better mind set ~ i can pack more junk in their,im not happy till the pc comes in a 60 pounds and you need a fork lift to move it around.
Not really useful for lan party's though but i have other computers for that use. *grins*
Old January 16, 2012, 02:50 AM
Umm.. I decided to go with the gene :D.. thanks to a35599.. By the way, what is X-fi
Old January 16, 2012, 02:24 PM
a35599's Avatar
Sound Blaster X-Fi - Wikipedia, the free encyclopedia
Old January 16, 2012, 02:59 PM
ok.. :D . but do you think the gene is better than p67?
Old January 16, 2012, 08:38 PM
JD JD is offline
They are both extremely good boards.
The Z68 Gene is newer though so it has a couple extra features, however it's only MATX, so unless you're specifically building a small form-factor PC, I wouldn't bother with it.
Go with the P67 or Z68 Extreme if you plan to use a full-tower case (or a mid-tower that supports EATX).
Old January 17, 2012, 03:07 AM
If I'm using antec six hundred II, will it be fitted for Z68 Gene?
Help me choose a TV thenewguy001 Off Topic 1 February 3, 2011 12:25 PM
Help me choose what to use! trayton Power Supplies 4 May 29, 2009 11:35 AM
Help me choose CPU's trayton CPU's and Motherboards 10 May 29, 2009 09:11 AM
Help me choose doup93 Video Cards 5 May 1, 2009 06:28 AM
choose one hohohee New Builds 16 April 12, 2009 12:18 PM
