Old March 11, 2008, 01:39 PM
Default New Build Advice
CPU: Q6600
MB: Asus P5E
RAM: G.SKILL F2-6400CL5D 2X2GB DDR2-800
Video: Sapphire 3870x2
P/S: Corsair 620HX
Case: Antec SLK3800B reusing old case
I won't be adding a second video card so I'm wondering if I should go with a cheaper MB.
Old March 11, 2008, 01:47 PM
sswilson's Avatar
Budget?
If on a low budget, a lower end P35 giga or ASUS board. If higher budget, consider a chipset with PCIe 2.0.
Old March 11, 2008, 02:47 PM
Babrbarossa's Avatar
What kind of case are you working with?
And what kind of budget range are you aiming for for a mobo, PSU, and case?
psst, wanna see my binder?
Old March 11, 2008, 03:55 PM
current case is Antec SLK3800B. Budget is around 1100
Old March 11, 2008, 05:48 PM
Well u can check the previous post made by me and see what some of the guys said, I went with the same CPU as you and I just ordered all my other items today. Good luck with the build!
Old March 12, 2008, 10:28 PM
edited
New Build - Could use some advice nophen CPU's and Motherboards 23 March 14, 2008 07:47 PM
Mobo advice for new build D1rtyB1rd CPU's and Motherboards 26 March 6, 2008 01:23 PM
New Build - Advice Welcome CasheKicker CPU's and Motherboards 47 March 5, 2008 07:07 PM
My Build: Any helpful advice? tgraszat14 CPU's and Motherboards 8 March 3, 2008 08:10 PM
New Build- need advice, opinion Etc UberMoo Off Topic 1 December 17, 2007 09:20 AM
