Old December 31, 2011, 03:21 AM
Default FX-6100 VS 1055T VS 960T
Dear HWCers,
I am currently contemplating on upgrading my current 720BE CPU. My motherboard is 790FXT-UD5P. Can I put FX-6100 in it? It is not in the official CPU support list but if anyone has tried something similar and would like to share.
Which one out of those three is best bang for the buck of an upgrade?
Old December 31, 2011, 04:31 AM
Don't bother. If it's not on the list then don't even try putting the Bulldozer in it. What exactly do you do with your machine?
Old December 31, 2011, 05:25 AM
supaflyx3's Avatar
Don't bother with bulldozer, get the 1055T or the 960T if you want to chance not having an unlockable quadcore.
Old December 31, 2011, 06:09 AM
I'd get the 1055Tand overclock it. Your board may eventually accept BD with a bios revision but I wouldn't bother...
Old December 31, 2011, 07:49 AM
The FX-6100 will be slower than either of the other options you listed unless you dump +300W in both cooling and power into overclocking it (see AMD Bulldozer FX-8150 Processor Review).
If you need the extra 2 cores (i.e. encoding, simulation, image / video editing), then get the 1055T. I don't know what stores you have access to, so I can't recommend one over the other. For gaming, 4 vs 6 cores doesn't matter (yet).
intel 2500K VS AMD FX 6100 Bl4ck_rainbow CPU's and Motherboards 9 December 18, 2011 04:00 PM
FX 8120/6100/4100 reviewed Bond007 Reviews & Articles from the Web 0 December 16, 2011 12:14 PM
P55 Upgrade build: AMD FX-6100 & 990FXA-UD3 dandelioneater New Builds 20 November 19, 2011 06:22 PM
AMD 960T sees the light of day as a retail chip Bond007 CPU's and Motherboards 13 October 18, 2011 01:19 PM
AMD Cancels Retail Phenom II X4 960T Thuban Quad Core Processors geokilla Press Releases & Tech News 17 May 13, 2010 10:08 PM
