Old March 10, 2008, 10:04 AM
yycraven's Avatar
I use to always think AMD was they way to go, but now running my Intel I will not go back. For a motherboard I like my Asus P5K its a great OCer and stable.
don't get me wrong the GA P35 DS3L is a great motherboard as well great bang for the buck.
Video cards well you have good choice now, my BFG 8800GT OC 512MB is a great card. I would buy one of those.
thats my two cents.
Old March 10, 2008, 08:37 PM
Default List of items for build
So I have compiled a list of items for my build, let me know what you think.
Antec Nine Hundred Black Steel ATX Mid Tower Ultimate Gamer Case
OCZ (OCZ600SXS) StealthXstream 600W Gamers Power Supply
Intel Core 2 Quad Q6600 Quad-Core Socket LGA775, 2.40 GHz, 1066 MHz FSB, 8MB L2 Cache, 65nm (Retail Box) (BX80562Q6600)
Gigabyte GA-P35-DS3L Socket 775 Intel P35 + ICH9 Dual-Channel DDR2 1066/800/667/533Mhz GigaLAN 8-Channel Audio Support 1333Mhz FSB
Patriot Extreme Performance DDR2 4GB (2 x 2GB) PC2-6400
BFG GeForce 8800GT OC nVidia GeForce 8800GT Chipset (625Mhz) 512MB (1800Mhz) GDDR3 Dual Dual-Link DVI PCI-Express 2.0 Graphics Card
Old March 10, 2008, 09:40 PM
i'd throw in a decent aftermarket heatsink/fan... you say your not into overclocking, but when you see how easy it is to oc that q6600 to 3.0-3.4 stable, and the performance gain while doing it you might change your mind.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old March 10, 2008, 11:23 PM
Moneyless's Avatar
And even if he doesn't want to spend much on a heatsink the Arctic Cooling Freezer 7 Pro is much better then the stock cooler and is only ~$25. Although I would recommend the Zalman CNPS9700 or the Thermalright Ultra-120 Extreme.
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
Old March 11, 2008, 06:17 AM
Default Final list
I have looked at several fans as well for cooling, now just a few more items and it'll be ready to buy!
Old March 11, 2008, 06:33 AM
Babrbarossa's Avatar
This is more like what I'd get- you're better off getting onwe 8800GT than two of those video cards- and you definitely shouldn't get that PSU- pretty much anything else but- it's very bad. Click on the links to get the actual prices which are lower than shown below- these items are mostly all on sale at direct canada.
The cooler master 690 is a good, large case as well- you can also try your build at NCIX- they price-match during checkout (just enter urls for cheaper listings) and you can combine their sale prices with everyone else's to get a great deal.
The antec i listed is a pretty decent case and has plenty of fan power included
Corsair VX550W 550W ATX 12V 41A 24PIN ATX Power Supply Active PFC 120MM FanYes $84.00
Asus P5K-E/WIFI-AP Atx LGA775 P35 DDR2 1333FSB 2PCI-E16 3PCI 2PCI-E1 SATA2 Sound Wlan Motherboard This might not be the best motherboard- probably a P35-DS3x http://www.ncix.com/products/index.p...cture=Gigabyte would be better value- only 100 bucks an da great board
  • Limit 2 per customer.
  • Usually Ships in 1 to 2 Business days.
Yes $149.88
Galaxy KFA2 GeForce 8800GT 600MHZ 512MB 1.8GHZ DDR3 PCI-E DVI-I HDCP HDTV Out Video CardYes $208.88
Seagate Barracuda 7200.11 3.5IN 500GB SATA2 8.5MS 7200RPM 32MB Cache NCQ Hard Drive
Yes $99.88
Samsung SH-S203B Black Sata DVD+RW 20X8X16 DVD-RW 20X6X16 Dl 18X/12X Int Dvd Writer Oem W/ Vista Sw
Yes $25.88
Antec Nine Hundred Mid Tower Gamer Case 900 Atx 9 Drive Bay No Ps Top USB2.0 1394 Audio
  • Limit 1 per customer.
Yes $95.99
Corsair XMS2 TWIN2X2048-6400 2GB 2X1GB PC2-6400 DDR2-800 Cl 5-5-5-18 240PIN Dimm Dual Channel MemoryYes $52.49
Old March 11, 2008, 07:07 AM
Intel Core 2 Quad Q6600 Quad Core Processor LGA775 Kentsfield 2.40GHZ 1066FSB 8MB Retail Box
Yes $255.88 $255.88 Gigabyte GA-P35-DS3L ATX LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound GBLAN Motherboard
Yes $86.92 $86.92 Corsair VX550W 550W ATX 12V 41A 24PIN ATX Power Supply Active PFC 120MM Fan Yes $84.00 $84.00 Galaxy KFA2 GeForce 8800GT 600MHZ 512MB 1.8GHZ DDR3 PCI-E DVI-I HDCP HDTV Out Video Card Yes $208.88 $208.88 Seagate Barracuda 7200.11 3.5IN 500GB SATA2 8.5MS 7200RPM 32MB Cache NCQ Hard Drive
Yes $99.88 $99.88 Samsung SH-S203B Black Sata DVD+RW 20X8X16 DVD-RW 20X6X16 Dl 18X/12X Int Dvd Writer Oem W/ Vista Sw
Yes $25.88 $51.76 Antec Nine Hundred Mid Tower Gamer Case 900 Atx 9 Drive Bay No Ps Top USB2.0 1394 Audio
Yes $95.99 $95.99 Corsair XMS2 TWIN2X2048-6400 2GB 2X1GB PC2-6400 DDR2-800 Cl 5-5-5-18 240PIN Dimm Dual Channel Memory Yes $52.49 $52.49
Old March 11, 2008, 07:08 AM
So all that is just over $940....can't beat that I don't think. Thanks a lot for your help!! This is a great site. Glad to be here.
Should I bother with 4gb of memory? I am only running XP and not sure if I will gain the full benefit of 4gigs.
  #19 (permalink)
Old March 11, 2008, 07:35 AM
Well- if it's not any more expensive that 2 then go for it- XP and Vista 32 bit versions have about 4GB memory address (max) which gets used by video memory and RAM so if you have a 512MB video card, You will still be able to use more than 3/4 of your 4GB of ram.
Good to have you aboard- be sure to post some pics once you get it built
  #20 (permalink)
Old March 11, 2008, 07:38 AM
You look to have a decent build there Funky, what size of monitor will you be using with the new system?
Q6600@3.2ghz
Asus P5N32-E Sli
4gb OCZ Platinum DDR2 @1100mhz
Antec P180
BFG GTX 260 Core 216
Corsair HX-620
Thermaltake Power Express 250W
Raptor150, WD 500gb. WD 300GB
X-Fi Extreme Music
Build a new rig newmill CPU's and Motherboards 32 November 12, 2007 07:37 PM
First build. l0ck Troubleshooting 15 July 25, 2007 04:24 AM
New build -Yes it's fun... Il Duce CPU's and Motherboards 15 July 8, 2007 07:57 PM
New Build and soon to go buy neurobashing CPU's and Motherboards 10 June 20, 2007 09:23 AM
My first ever build, help me out paolo CPU's and Motherboards 31 June 9, 2007 04:04 AM
