Old December 28, 2011, 02:52 PM
Default Cpu switch
Hey HWC,
I'm wondering my i3 processor with a i5 760 processor and I'm wondering if I changed the processor will I lose all my data on my hard drive or do I have to format my hard drive before switching the cpu thanks!
P.S. Is it wise to make a backup? Could I lose all my information?
-Brandon
Old December 29, 2011, 06:56 AM
Making backups is always a good idea before poking your hardware (e.g. I've busted the SATA connector of a hard drive when swapping hardware). You should have backups set up all the time if you care enough about your data that you're posting about it
If you switch only the CPU, you won't lose any data unless you break something. You don't have to format your hard drive, but I would advise that you update your motherboard's BIOS and clear the CMOS (both of which should be explained in your motherboard's instruction manual) before upgrading CPUs. That will allow you to avoid cases like your motherboard loading improper settings for your new CPU.
Old December 29, 2011, 07:19 AM
If the system has never been overclocked resetting and updating the bios is unnecessary
Old December 29, 2011, 04:40 PM
Thanks frontier204 and enaberif for the help.
Old December 29, 2011, 04:51 PM
Galcobar's Avatar
Presuming the original BIOS supports the new chip. Best to check that with the motherboard manufacturer, they'll have lists of supported processors and the minimum BIOS revision required on their website.
Old December 29, 2011, 05:21 PM
3.0charlie's Avatar
If the processor is not recognized by the OS, un-install the CPU drivers found in Device Manager and restart. The proper drivers for the new chip will be installed upon restart.
Hydro-Quebec is salivating...
Old December 29, 2011, 05:33 PM
KaptCrunch's Avatar
i hate when people confuse the word revision to bios when its VERSION
revision is for MB, that manufactor change a chip supplier on MB meaning a new instruction for MB
Note brando533
check revision of MB for some manufactors may have 1 to 3 bios to a MB model due to revision of MB
get correct bios to your MB as per revision, use DOS to flash bios and
most manuf flasher will reset bios by thier app
Old December 29, 2011, 05:37 PM
KaptCrunch's Avatar
also brando533 OS may need to re-register with MS if using windows
Old December 29, 2011, 06:01 PM
Supergrover's Avatar
I have yet to have to re-activate/reg with MS from a cpu upgrade, mobo's for sure but not cpu's.
R.I.P.
Old December 29, 2011, 06:07 PM
KaptCrunch's Avatar
seems ever time i changed hardware-drivers in XP i got that nag screen
How switch HDD to SSD Kilauea Mobile Computing 17 June 10, 2011 02:09 PM
power switch CTA Off Topic 7 March 21, 2011 01:56 PM
Hardware Switch bvsbutthd101 Storage 9 July 2, 2010 05:02 PM
[WTB] Gigabit switch Sipek Buy/Sell & Trade 1 April 27, 2010 09:03 PM
My Switch Mod kcksteve Networking 0 September 24, 2007 04:25 PM
