Old December 22, 2011, 08:22 PM
JD JD is offline
Originally Posted by r0k0 View Post
wouldn't a GTX 560 be slower then a 5970 ? the 5970 is a Dual GPU card with 2GB compared to 1 GTX 560 with 1GB
I would say the GTX560 outperforms the HD5970 in 3DMark at the very least.
Compare only the CPU scores, not the overall score, then you'll have a slightly more accurate picture.
Old January 5, 2012, 10:02 PM
i will go 2500K for sure. you don't really need extra thread for daily use.
Old January 5, 2012, 10:26 PM
bissa's Avatar
really depends on your acceptable budget. if you are willing to spend some more for fractionally better performance once in a while, then go for it. it will last a little longer for when more things start supporting 8 cores.
I would say go with what was said earlier, save and get an LGA2011 CPU such as the 3930 or 3950 (if that's out). as that would be an actual upgrade and would be significant upgrade at that because of the extra 2 cores and extra 4 total threads.
Old January 5, 2012, 10:28 PM
How long have we been saying "when things start using more cores"? . Fact is 2500k does everything most people need for quite a bit less
Old January 5, 2012, 11:45 PM
bissa's Avatar
good point. I guess I'm also looking at it from a folding point of view.
i7 2600K or i5 2500k? SnowJim CPU's and Motherboards 10 November 19, 2011 12:17 PM
[WTB] Intel 2500k/2600k richuwo11 Buy/Sell & Trade 1 September 30, 2011 08:58 AM
[WTB] WTB 2600k or 2500k, also a s775 mobo Table21 Buy/Sell & Trade 2 September 2, 2011 07:42 PM
i7 2600K vs i5 2500K (Almost built) sstrucel New Builds 9 August 17, 2011 09:48 AM
2500k or 2600k kyle_L New Builds 4 August 4, 2011 10:49 AM
