1) probably. depends on the mobo (ie high end ,mid range, low end). pci-e gen 3 is a meh feature right now. Dont see any gpus coming out that will NEED gen 3. the gen AFTER that...maybe.
2) same as SandyBridges. the pch will just be a refresh of the pch on SB with maybe some tweaks done to it (but I doubt it will amount to much)
3) same as SB....but will vary from mobo to mobo depending on if they use more (or less) usb 3 controllers (ie a discrete usb chip such as the asmedia usb 3 controller chip)
4) probably. most come with it now. for better or for worse its here to stay. but will prolly vary based on mobo lineups (see answer 1 and 3).
