Old December 16, 2011, 11:59 PM
The Quicken's Avatar
Default Thermal Paste
Quick Q & A:
Easiest/effective way to apply without using finger?
Old December 17, 2011, 12:10 AM
Supergrover's Avatar
Pea method or for hdt line method.
R.I.P.
Old December 17, 2011, 12:27 AM
supaflyx3's Avatar
I use the credit card method, unless the paste is really thick then I use the pea method.
Old December 17, 2011, 02:34 AM
Arctic Silver 5...thick stuff. Pea method makes sense to me, but just so many vids showing ppl covering the entire surface evenly (usually card method).
Old December 17, 2011, 03:54 AM
LaughingCrow's Avatar
Artic Silver have instructions - PDF IIRC:
Arctic Silver, Inc. - Instructions
Old December 17, 2011, 06:44 AM
FreeKnight's Avatar
Q-tip inside a ziploc bag if you want to control the spread like if you had used your finger.
Old December 17, 2011, 09:45 AM
Adzsask's Avatar
Pea sized grain is WAY to much, a rice grain is more like it. If you want to spread it around without making a mess, cut the corner of a plastic bag and use your finger.
Old December 17, 2011, 09:59 AM
spreading is for peanut butter. just drop a rice size in the middle and call it a day
Old December 17, 2011, 12:29 PM
KaptCrunch's Avatar
Default real deal
mine is happy face but X does well too
How Thermal Compound Spreads - YouTube
Old December 17, 2011, 12:51 PM
Like everyone else said, pea method. But if you have a Hyper 212+ or A50 or similar HDT cooler, then apply the thermal paste in thin, short lines between the copper heatpipes.
What thermal paste for my GPU? Polygon Video Cards 9 December 12, 2010 01:47 AM
GTX 580 thermal paste mikellini Video Cards 13 November 17, 2010 11:37 PM
Thermal Paste r0k0 Overclocking, Tweaking and Benchmarking 11 February 15, 2010 11:53 PM
Thermal Paste miggs78 Water Cooling 4 September 10, 2009 07:17 PM
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 06:43 PM
