-   -   Motherboard doesn't allow overclocking (http://www.hardwarecanucks.com/forum/cpus-motherboards/49448-motherboard-doesnt-allow-overclocking.html)
Sevada December 15, 2011 03:12 PM
Hey guys
I have one of those pre-built PCs from HP. Bought it about 5 years ago. It's a great PC but now that I am more into computers etc. I want to learn how to overclock the CPU. However, the BIOS doesn't have the options available; it's locked so to speak. Is there a way to "unlock" the options to overclock the CPU?
Some information about my PC: I have a Q6600 at 2.4Ghz and an ASUS IPIBL-IP Benicia motherboard.
supaflyx3 December 15, 2011 03:16 PM
No there is not, there are software options out there but I wouldn't recommend it...
jibz December 15, 2011 04:14 PM
there is always the possibility of swapping the mobo out for a cheap used 775 mobo
zsamz_ December 15, 2011 04:48 PM
google pin mod:whistle:
or buy a proper board
Soultribunal December 15, 2011 05:08 PM
That will only work if the original board does not have proprietary connectors.
Most pre-builts do just for that reason.
To The OP. I wouldn't even bother with that current one.
-ST
Sevada December 16, 2011 02:11 AM
-ST
Thank you all for your replies. I guess I will go for a new mobo although a proper LGA775 mobo is kind of hard to come by these days.
I want to keep my Q6600, overclock it and use it for the next 1/2 year(s).
stoanee December 16, 2011 06:11 AM
Should be able to buy a used mobo.
dpk33 December 17, 2011 12:53 PM
Buy a cheap P35/x38 or P45/x48 mobo and case then overclock it. The total shouldn't be over $100. I'm not sure about other chipsets, but I had the best experience overclocking Core 2 Quads on P45 and P35s.
Sevada December 22, 2011 03:04 PM
Hey guys, I had to come back on this. I have been looking around for a decent P45 mobo, both retail and online shops, and used ones, but I can't find any.
I did find some G41 boards, both online and in retail shops. It's funny how P45 is not available anymore, but the G41 is. I guess it's a marketing thing...
What do you think, will the G41 be any good for overclocking? I found some boards with DDR3 1333 memory, is this any good for overclocking the Q6600?
