  #21 (permalink)
Old December 18, 2011, 09:32 PM
Mir Mir is offline
How come I cannot see a FDD controllrt
  #22 (permalink)
Old December 21, 2011, 01:00 PM
Soultribunal's Avatar
If you really need a FDD get a USB one. They are $30-40.
Why are you so dead set on Legacy parts?
-ST
  #23 (permalink)
Old December 21, 2011, 01:03 PM
Supergrover's Avatar
Common nowadays since mostly everything has turned to usb.
Buy usb drive or use one you have, if you have stuff on fdd now migrate it to the usb before you build.
Simple.
R.I.P.
  #24 (permalink)
Old December 22, 2011, 06:49 PM
Mir Mir is offline
Lightbulb
Extra Added Cost,
Using a Slot PCI
I am tring to keep it simple and little bit lower on COST.
I need IDE for my Custom Firmware IDE Optical Drive; which allow me to do stuff; which normal optical drive won't let you.
I have old softwares which work fine with Native com ports. Other wise I have two or three different Kind of com port; cause not a single can offer what I need. It is simple for me to get a built in com port.
-ST
Simple.
I have already share why I have my needs
Good Motherboard for the 1155 socket TomMiller New Builds 7 November 18, 2011 03:29 PM
[WTB] [FOUND] Noctua DH-14 for socket 1156/1155 Alpine Buy/Sell & Trade 9 April 5, 2011 03:34 PM
Possible 1155 socket burn? [TechReaction] Delavan Rumor Mill 7 January 17, 2011 04:07 PM
Gigabyte P67 UD7 1155 Intel [Youtube] ZZLEE Reviews & Articles from the Web 16 November 28, 2010 12:40 PM
