Old December 12, 2011, 10:38 PM
Default Cpu life
i have 2600 non k cpu
should i change my stock cooler in order to increase my cpu life or be with stock
Old December 12, 2011, 10:48 PM
Perineum's Avatar
CPU will likely run forever with the stock heatsink.
I have yet to see a dead cpu from aging.
Old December 13, 2011, 03:40 AM
Bond007's Avatar
I don't think you will gain any life by changing the heatsink.
Old December 13, 2011, 08:40 AM
great_big_abyss's Avatar
I don't think it will extend your life.
However, I switched the stock downdraft cooler on my AMD 965 to an aftermarket cooler. The difference in noise was remarkable, and well worth the $40 I spent on the cooler.
Old December 13, 2011, 10:30 AM
Look around at all the Pentium 4 rigs that are still running on stock heat sinks, many of which run hotter than an i7 2600 - your CPU will get outdated long before it degrades. Just make sure to keep the computer relatively free of dust (this goes for any using cooler).
CPUs are designed and covered by warranty using their stock coolers. Aftermarket cooling is mainly for lower noise, better temperatures while overclocked, and in some cases to fit in a certain form factor that a stock cooler cannot fit.
EDIT: missing word
Old December 13, 2011, 11:42 AM
Adzsask's Avatar
Sandy bridge is the only stock cooler I would ever tell any intel user to keep using, used to toss them out in the stores before I got home, but they grew into there crappy stock coolers with drops in die size and lowered voltages.
Old December 13, 2011, 01:38 PM
A stock cooler for stock speeds or very minor overclocking, if your computer runs at a decent temperature with modern hardware, you will outgrow its potency long before it "dies" of old age or sufferes degradation.
As long as temps/voltages are where they should be Intel/AMD both warranty them for 3 years, and have artificial testing to almost 100% guarantee they will last 10 years+ though most folks never use them that long :O
Old December 13, 2011, 10:03 PM
Mir Mir is offline
Arrow
I had K6 2, I suppose to run 266 Bus speed,
I ran 300 Bus speed on stock Cooler in Texas.
It lastest 6 Years before it started to give errors.
It would run fine at stock but not OC speed.
Old December 15, 2011, 01:34 AM
NI3 NI3 is offline
I had an E5200 at 3.5Ghz with the stock cooler. The chip is still running fine, in a cousins computer.
As said, a non overclocked cpu should last for years with the stock cooler.
For those who take life too seriously jay51 Off Topic 4 September 18, 2010 08:10 AM
Windows XP has a bit more life enaberif Press Releases & Tech News 49 June 23, 2009 10:55 PM
Life unplugged. misterlarry Off Topic 1 April 5, 2009 06:13 PM
BioStar BIO-Life enaberif CPU's and Motherboards 14 October 15, 2008 09:34 PM
