Old December 12, 2011, 05:02 PM
Exclamation motherboard issues
my motherboard says
2000(O.C.)/1866(O.C.)/1600(O.C.)/1333/1066 MHz
what will happen if i put in 1866 MHz ram,
will it not boot?
will it boot?
do i have to buy 1333 MHz RAM instead?
What will i have to do to make it work good?
Old December 12, 2011, 05:05 PM
sswilson's Avatar
It should boot no problem, but you'll have to make adjustments in the bios to get it to run at the rated speed.
Old December 12, 2011, 05:28 PM
techman95's Avatar
all it means is that 2000 is the max supported. when it has the O.C. next to the number all that means is that you have have to go into the bios and manually set it to that frequency no problem at all.
Amd....definitely a blond female.....not much on the cpu side, but always strutting about showing off her gpus
Corsair Issues Warning of Possible H100 Fan Controller Issues SKYMTL Press Releases & Tech News 8 October 1, 2011 03:03 PM
Ram Issues I Think? Tainger Troubleshooting 5 January 28, 2011 02:13 PM
*IMPORTANT* Phenom II x4 955 C3 and Motherboard v1.0 Issues backpack New Builds 0 December 26, 2009 05:03 AM
Motherboard Waterblock Compatibility Issues bkh2 Water Cooling 2 July 31, 2009 09:15 PM
Motherboard Issues ImmaPC CPU's and Motherboards 13 December 14, 2008 12:45 AM
