Old March 7, 2008, 01:41 PM
Rapid-X's Avatar
Originally Posted by Cptn Vortex View Post
Those CPUS would not work. They are MP, meaning Multiprocessor. Right now you should only be looking for 3000 series Xeon chips, as they are the only ones that would work in certain S775 systems.
how can i tell
Old March 7, 2008, 01:43 PM
Rapid-X's Avatar
3.06GHz / SL6GH / 533MHz-FSB / 512KB L2
Processor Specifications:
  • sSpec Number: SL6GH
  • CPU Speed: 3.06 GHz
  • Bus Speed: 533 MHz
  • Bus/Core Ratio: 23
  • L2 Cache Size: 512KB
  • L2 Cache Speed: 3.06 GHz
  • Package Type: Socket 604
  • Manufacturing Technology: 0.13 micron
  • Core Stepping: C1
  • CPUID String: 0F27h
  • Thermal Design Power: 85W
  • Thermal Specification: 73°C
Description
WORKING P4 XEON PROCESSOR
SL5Z9
SL5Z9
2 GHz
400 MHz
20
512 KB
2 GHz
Package Type:
Micro-FCPGA
0.13 micron
B0
0F24
58W
70°C
1.5V
Old March 7, 2008, 02:00 PM
Cptn Vortex's Avatar
Yes I believe that is one of the older Socket 603 Xeons. Definitely not compatible with mainstream desktop boards. Like I said earlier, you would need one of the 3000 Series Xeon CPU's. IntelŽ XeonŽ Processor 3000 Sequence Overview
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old March 7, 2008, 02:17 PM
MacJunky's Avatar
So.. we could go here and change the package filter to LGA775 and that would be it?
Intel Processor Finder thingy
Old March 7, 2008, 02:27 PM
Yup. Keep in mind though, there are other requirements. For example, a E3110 will not work on a board without 45nm CPU support. And the X3210 needs boards that support quadcores. Those kinds of things.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
Old March 7, 2008, 02:55 PM
Rapid-X's Avatar
now im lost just sell me urs lol
Old March 7, 2008, 03:40 PM
What motherboard do you have or what motherboard are you looking at buying. We can go from there
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
Old March 9, 2008, 05:07 AM
Rapid-X's Avatar
asus p5n32 sli
Xeon Workstation Build TOBoiDan CPU's and Motherboards 6 February 8, 2008 11:35 AM
C2D vs Quad vs Xeon enaberif CPU's and Motherboards 9 August 9, 2007 10:40 PM
Is this a good deal on a Xeon X3220? r00tman CPU's and Motherboards 3 July 11, 2007 08:13 PM
What's the difference between Q6600 and Xeon 3220? r00tman CPU's and Motherboards 13 June 21, 2007 05:41 PM
