Old December 8, 2011, 01:30 PM
great_big_abyss's Avatar
I think you would notice a difference by upgrading the motherboard and the RAM, though.
Old December 8, 2011, 05:09 PM
Bond007's Avatar
I don't think its as big of a change as you are making it out to be. ddr2 to ddr3 is <5% difference if I recall correctly (I believe it was a ddr2 1066 vs ddr3 1333 comparison and most tests were within 1 to 3 %). I will try to find the review.
Old December 8, 2011, 05:44 PM
geokilla's Avatar
The price/performance is definitely not worth it.
Old December 9, 2011, 09:22 AM
geokilla's Avatar
Is this a good SSD to upgrade to?
OCZ 120 GB Vertex Plus Series SATA II 2.5" SSD : Memory & Memory Upgrades | Dell Canada
Old December 9, 2011, 11:50 AM
I run the 1090t but then I use apps that can use multiple cores and it's the cheaper option. Running games and apps and apps and apps isn't a problem for this cpu. You'll have zero issue with Great Big Abyss' recommedation. Look at the comparison chart very closely to what YOU are using the computer for. The 1100 6 core isn't that far behind the i5 for a fraction of the cost and 2 more cores.
All 4 of these are good it's your price point that is your concern.
i5 @ 230 dollars 4core @ 3.3ghz 6meg cache
amd 965 130 dollars 4core @ 3.4ghz 8meg cache
amd 980 170 dollars 4core @ 3.7ghz 8meg cache
1100t 205 dollars 6core @ 3.3ghz 9meg cache
Either way you'll have a decent computer it's just a money thing right?
500 bux you can get 965 $130 + mobo 130ish + crucial M4 SSD 128 gig 220 dollars = 500 dollars.
If you think the SSD won't help your crazy... it's the single greatest upgrade you can make.
Mah Rig now
Mah Rig before
My stuff for sale.
Old December 9, 2011, 11:54 AM
Originally Posted by geokilla View Post
The one you are looking at has a lot of issues right now too apparently.
Crucial m4 is the ONLY SSD you wanna buy right now imo.
Mah Rig now
Mah Rig before
My stuff for sale.
Old December 9, 2011, 04:47 PM
howpet's Avatar
You"ve got the itch!!
Take something apart that"s working perfectly fine and try to make it better...we"re all with you.
Don"t forget; the cpu, mobo, memory are going to bring in some coin so you might be able to up your budget a bit and go Intel + SSD
Old December 9, 2011, 08:18 PM
Look whos selling a 6 core for 140 bux. Best deal you'll find and he won't screw you around.
http://www.hardwarecanucks.com/forum...dom-stuff.html
Mah Rig now
Mah Rig before
My stuff for sale.
  #19 (permalink)
Old December 9, 2011, 11:52 PM
I've always like Intel's SSDs. Several friends of mine have used them and never had a problem.
  #20 (permalink)
Old December 10, 2011, 06:45 AM
NI3 NI3 is offline
If all you play, or what you mostly play is SC2, then you really don't need to upgrade to thuban. SC2 only uses 2 cores if I remember correctly, and multitasking will see nothing from the extra cores.
I'd upgrade to an SSD, and that case to be honest. Not something too crazy, but something a little better.
Need to replace my Atom 230... Dr_BenD_over HTPC Systems & Software 3 October 21, 2011 09:38 AM
Looking to replace Tri-SLI GTX280 setup need advice. FrankyG Video Cards 17 September 24, 2010 09:42 PM
Replace HDD? Hunt Storage 11 February 15, 2010 12:33 PM
Replace GPU sticker... mattlef Off Topic 4 September 28, 2009 07:43 PM
Replace my 7800gtx sli setup with a single 9800gt? recklessftw Video Cards 5 August 16, 2009 07:43 PM
