Old December 6, 2011, 08:03 PM
Default Gigabyte 990FXA-UD3 causing problems
First real build I have done on my own.
I have:
Gigabyte 990FXA-UD3 mobo
AMD FX-6100 AM3+ processor
Antec EarthWatts Series EA-750 Green 750W ATX12V v2.3 PSU
Radeon 4850 512MB GPU
8 GB (2x4GB sticks) DDR3 1600 RAM
Antec 900 Case
I don't know what the problem is but the system won't boot at all.
Old December 13, 2011, 09:27 PM
is this a new build? as in new motherboad? might be a bios issue, my board needed a bios update in order to support the new FX ship... could u give more details
Old December 18, 2011, 03:07 AM
Trial Member
Hi, i have same cpu and motherboard and the system wont boot. Did you solve the problem?
Old December 18, 2011, 04:19 AM
NI3 NI3 is offline
See if you can find out when the motherboard was manufactured (like a sticker or something on the box), as if it was before BD then you may need a bios update.
Old December 18, 2011, 11:38 AM
Don't know why mine wouldn't work at first. I got it to boot by putting it together on my bed as just the mobo, CPU, GPU, memory, and PSU. My board is Rev. 1.1 though, so check that. Also make sure you have a decent PSU (really need at least 550W).
What sucks is that if you're updating to an AM3 board like I was and you get rev. 1.0 you're basically screwed into finding a supported CPU to flash the BIOS for the FX-6100 to work.
Gigabyte F6e beta bios for 990FXA-UDX boards dandelioneater CPU's and Motherboards 1 December 13, 2011 09:26 PM
Gigabyte 990FXA-UD3/UD5/UD7 Mavvens CPU's and Motherboards 5 October 3, 2011 09:40 AM
Dual Booting causing problems for the 1st time element291 Troubleshooting 5 May 15, 2009 04:47 PM
Problems Overclocking with Gigabyte GA-P35-DS3L DukeNukem Overclocking, Tweaking and Benchmarking 8 December 13, 2007 05:35 PM
