Old December 6, 2011, 11:32 AM
Default GIGABYTE GA-Z68XP-UD3 1155 Motherboard Questions
So I have purchased this motherboard and it has lots of places to hook up a 64 GB SSD and a 750 GB HDD and a BluRay player. The SSD and HDD are supposedly 6gb/s devices. Should I hook them up to sata3_0 and sata3_1 or 1 in one and the other in the Gsata3_6 connector? What about the Blu Ray? does it matter? Not interested in RAID configurations.
Chipset:
  1. 2 x SATA 6Gb/s connectors (SATA3_0~SATA3_1) supporting up to 2 SATA 6Gb/s devices
  2. 4 x SATA 3Gb/s connectors (SATA2_2~SATA2_5) supporting up to 4 SATA 3Gb/s devices
    * The SATA2_5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
  3. Support for RAID 0, RAID 1, RAID 5, and RAID 10
    * When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip:
  1. 2 x SATA 6Gb/s connectors (GSATA3_6, GSATA3_7) supporting up to 2 SATA 6Gb/s devices
  2. Support for SATA RAID 0 and RAID 1
GIGABYTE - Motherboard - Socket 1155 - GA-Z68XP-UD3 (rev. 1.3)
Old December 6, 2011, 12:57 PM
You have it right the way you first suggest. The Intel chipset controller is faster and easier to use than the Marvell unit.
2600K @4.6
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
Gigabyte GTX780
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old December 6, 2011, 01:09 PM
Eldonko's Avatar
Hardware Canucks Reviewer
With a 64GB SSD and 750GB HD you really should be setting up SSD caching for optimal performance. Create an OS partition on the 750GB, Install windows, and then run Gigabyte EZ Smart Response utility to set up caching.
[FS] Gigabyte Z68XP-UD5 Eldonko Buy/Sell & Trade 16 October 21, 2011 04:27 PM
Gigabyte Z68XP-UD5 Motherboard Review Comment Thread SKYMTL CPU's and Motherboards 4 October 7, 2011 11:29 AM
GIGABYTE Z68XP-UD3-iSSD @ Legit Reviews geokilla Reviews & Articles from the Web 1 August 26, 2011 08:42 PM
Gigabyte P67 UD7 1155 Intel [Youtube] ZZLEE Reviews & Articles from the Web 16 November 28, 2010 01:40 PM
